Results 1 to 20 of 20
Thread: affordable metal and plastic VGs
    Dec 2011
    11
    Hey guys- just wanted to let you know that Landshorter VGs are back Been making and selling these since 2004 and after selling over 2000 sets took a break for a few years, but now we're back with really aggressive low pricing (think we're the cheapest on the market for plastic VGs) plus we now offer METAL VGs for the experimental market. Same low-drag-high-performance shape but in a highly corrosion resistant aluminum alloy that folks have been requesting for extra toughness and solvent resistance (gasoline, cleaning agents, etc).
    For those that don't know me I'm a long time EAA homebuilder, current DER, A&P, PPSEL, former DAR, etc. All that alphabet soup stuff. So basically I have an aircraft habit
    So if you want to improve the performance of your aircraft or just read some fun backcountry flying stories check out my new website.
    www.landshorter.net
    Thanks and blessings
    Joa
    Likes OzAK, Nolan liked this post
    Jan 2017
    Utah/Alaska
    363
    Pics would be nice for the new metal ones!
    Dec 2011
    11
    Quote Originally Posted by astjp2 View Post
Name:	PLASTIC VS METAL_1.png
    Here you go. As you can see, the metal ones look very similar to the Lexan ones. That's because the plastic VGs I designed in 2004 were based on extensive wind tunnel tests at a top university that minimized the drag for the maximum benefit of energized air.
    You can put nearly any tab on your wing at an angle and it will create a vortex but the size, shape, and placement will dictate the drag performance and how cleanly the vortex adheres to the wing. For example, a gent from Australia bought a set from me a number of years ago and tried to copy my plastic VGs but got it wrong on the most important part- the upper back corner. If you round that corner you just add drag without the cleanly shed vortex. His VGs also are too thin and flexible and crack over time with exposure to sun and use.
    The shape of both my plastic and metal VGs has been highly optimized which really makes a difference when looking for the most performance possible out of your aircraft.
    Hope that helps
    Thanks OzAK thanked for this post
    Likes OzAK liked this post
    Utah-Jay's Avatar
    Aug 2020
    Heber City, UT
    363
    Weight difference between the plastic and metal for a full set of 120?
    Dec 2011
    11
    Quote Originally Posted by Utah-Jay View Post
    The weight difference for a full wing kit is about 7 ounces- or less than a cup of water (or similar). Not even a remote consideration when compared to the benefits you get in stall speed and handling.
    Jan 2017
    Utah/Alaska
    363
    Quote Originally Posted by harrisonaero View Post
    Do you have curved and flat options? Templates?
    Dec 2011
    11
    They all have a very slight curve to them. Most surfaces you'll put them on will be a bit curved so they fit nice but if it's truly a flat surface then the concave portion just gets filled with a tiny amount of glue. That's a better option than having the ends curl up.
    And yes, they come with templates and a full manual.
    Good questions and thanks for your interest
    Thanks astjp2 thanked for this post
    Likes astjp2, Brandsman liked this post
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,313
    FYI I have Joa's Lexan VG's on my Cub for over 10 years now. Never had one break or come off.
    Dec 2011
    11
    Quote Originally Posted by Bugs66 View Post
    Thanks for the kind words! Yes, our Lexan ones are pretty tough. They're thick enough to not easily break (can hit them with a hammer, etc) unlike other flimsy ones on the market. Their achilles heel is solvents such as spilling gas on them or cleaning around them with something strong like acetone and they don't really like getting bent in cold weather. Hence the reason we came out with our metal VGs. So now folks have options
    BTW back when I was doing the DAR thing I think I did the cert signoff on your neat plane, right? Been a while
    Dec 2011
    11
    I really like this forum and have been a member for 10 years so as a reflection of that I'll offer you guys 25% off until the end of the year. Use SUPERCUBDOTORG2021 for the c*upon c*de when you check out. This is good for either our metal or our plastic VGs. Get that performance you deserve for Christmas
    Also, if any of you have aircraft businesses and want to set up a commercial account we're doing that right now so hit me up at info@landshorter.net and we'll get you going.
    In a nutshell we want to take over the experimental VG market again so are hitting on all cylinders. Any ideas you might have there- we're all ears.
    Aug 2021
    22
    Hey Joa
    Just put an order in for two sets, one for the flyer and one for the rebuild! Can you recommend what adhesive you use with the metal VGs?
    Cheers
    Tom
    Dec 2011
    11
    Quote Originally Posted by J4A View Post
    Hey Joa
    Cheers
    Tom
    Thanks Tom!
    We've found that the best adhesive is still a gel cyanoacrylate (super glue). Recommendations are in the manual. We'll get you the info you need
    Nov 2015
    Fairbanks, AK
    117
    Hi all! I ordered a full set for my build (set of 120 for my wings and 80 for the tail) and Joa has been as good as gold taking care of me, providing info, free shipping, and prompt service. Trifecta of doing business. I got the aluminum VGs and they are top shelf quality. The paperwork provided is excellent with clear instructions, good templates and the engineering behind the VGs. Order with the utmost confidence.
    Mike “Oz” Osborne
    Fairbanks
    Likes jrussl liked this post
    Dec 2011
    11
    Quote Originally Posted by OzAK View Post
    Hi all! I ordered a full set for my build (set of 120 for my wings and 80 for the tail) and Joa has been as good as gold taking care of me, providing info, free shipping, and prompt service. Trifecta of doing business. I got the aluminum VGs and they are top shelf quality. The paperwork provided is excellent with clear instructions, good templates and the engineering behind the VGs. Order with the utmost confidence. Mike “Oz” OsborneFairbanks
    Thanks Mike, appreciate the kind words. We aim to please
    akavidflyer's Avatar
    Apr 2010
    Soldotna AK
    232
    I had the lexan ones on my Avid flyer. I used "plasti zap" when I put them on and it "melted" through the paint and adhered to the fabric, as in, they are / were not coming off without taking fabric with them using the plasti zap over the poly products.
    Agree that the templates and instructions were great, I will be ordering a couple sets of the aluminum ones!
    Mauleguy's Avatar
    Aug 2002
    794
    I did a test of sorts when I put the VG's back on Bushwacker last time after rebuild. I used the Loctite® 330™ Depend® Adhesive to attach the Micro Vortex Generators to one wing and a buddy said why not just use gel cyanoacrylate . So on the next wing I tried the Super glue, I found out why you should not. Every time I looked at the top of the wing, with the Super Glued ones it was missing another. I rarely had a problem with the ones that I used the 330 on. I took all the Super Glued ones back off and sanded and glued them back on again with the 330. They seemed to stick good in the beginning but if you just push on them they would pop off. Try that with the Loctite 330 and it won't come off with out taking the paint too. YMMV
    Will never put VG's on again with anything other than the 330, it is more work but you can hook them washing the wing and not pull them off. Throw a fuel bag up without knocking two at a time off...
    Greg
    Thanks marcusofcotton thanked for this post
    Likes DENNY, siegel185 liked this post
    Dec 2011
    11
    Quote Originally Posted by Mauleguy View Post
    Greg
    Thanks Greg, good info. Loctite makes great products.
    3,211
    For me Loctite would rip off any topcoat over silver on fabric. I don't recall seeing much bare fabric under the disappeared VG.
    3,749
    It would be interesting to put some VG's just in front of the ailerons on my 180 & see just what difference they made.
    Kinda like how the Swift & Stinson have slotted outboard leading edges
    3,211
    ^^^^Seal the ailerons like Sportsman Cuff does. VG's need smooth air flow to work. At higher AOA it's turbulent back there.
  1. Found one that is probably more affordable for me.
    By Farmboy in forum Video Vault
    Last Post: 12-11-2016, 01:29 PM
  2. Plastic Nation?
    By Scouter in forum Cafe Supercub
    Last Post: 12-22-2013, 12:25 PM
  3. Plastic Fuel
    By cubdriver2 in forum In The News
    Last Post: 08-21-2012, 09:51 AM
  4. Plastic to Oil, or Fly your Cub a little cheaper.
    By Roger Peterson in forum Cafe Supercub
    Last Post: 02-02-2011, 06:04 PM
