Results 1 to 3 of 3
Thread: Tailwheel anti-rotation pin
    jrussl's Avatar
    Jul 2005
    Madison, WI
    685
    What do you think happened here? I am guessing either an incorrect assembly (me), mashing the pin down. Or I let it get worn and sloppy enough for the brass ring and dust cover hop over the pin and mash it down. No issue either way as I am now rebuilding it after 1,600 hours.
    3,200
    I've had that happen on a couple. Wear I guess plus the lower fork bearing gets loose and makes for slop. Had to drill a small #40 hole in the fork below the pin to drive it out, then sealed hole with RTV.
    Apr 2009
    AK
    261
    I tig a bolt or screw to it and pull them out- common to be worn like that...
  1. Replies: 4
    Last Post: 12-14-2019, 05:41 PM
  2. Bushwhell rotation and care
    By teeweed in forum Cafe Supercub
    Last Post: 09-18-2006, 10:25 AM
  3. spark pulg rotation
    By busbart1 in forum Cafe Supercub
    Last Post: 02-29-2004, 03:18 PM
