Results 1 to 14 of 14
Thread: But it was that way when I bought it...
    Jan 2017
    Utah/Alaska
    363
    It is getting frustrating when owners/operators tell me that. I am trying to annual their airplane and the fiberglass landing gear is cracked...both landing gear and then the owners says he has been watching it for a while. I would be embarrassed to say that...needless to say I changed the gear legs but WTF you can afford an airplane but don't want to fix it right? I know that each type of airframe has specific idiosyncrasies and there are expert and novice mechanics, so understanding and specializing has its merits and the knowledgeable people on here about all types of aircraft is outstanding. I have been getting indoctrinated on the Rotax 912's, and the more I work on them the more mixed I feel about the good and bad that comes with them compared to a Lycoming or Continental...sorry I just need to vent. Tim
    Likes RaisedByWolves, Pete Schoeninger liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    841
    Quote Originally Posted by astjp2 View Post
    I would really like to hear more about this
    7,678
    They are sufficiently different that you need to go to a school or do some serious study. Even changing the oil is “different.”
    1,212
    Might want to refer the owner to 91.405!
    Jan 2017
    Utah/Alaska
    363
    I have 35 LSA 912's and 4 certified at my day job...maybe we should start a Things to know about Rotax 912's thread? Still doesn't fix owner attitudes, this guy will basically have a like new airplane, 5 year change out on the hoses and new landing gear, fresh fluids, he did concede to change them but its just frustrating...
    Jan 2017
    Utah/Alaska
    363
    Here are a few rotax pics, I seem to repair a lot of mid time jugs, that run 100LL. the oil on the jug came from a cracked copper washer under the bolt for the torque check on the gearbox. The entire top of the engine was covered in oil.
ID:	58221   Click image for larger version.
ID:	58222   Click image for larger version.
ID:	58223   Click image for larger version.
ID:	58224   Click image for larger version.
    Likes Charlie Longley, tedwaltman1 liked this post
    21,494
    I would have told him to sign it off then.
    21,494
    I have gotten better and better at choosing my customers, figuring out who I do and don't want to work for. Learned some valuable lessons over the years that cost me dearly.
    WWhunter's Avatar
    Aug 2003
    1,563
    Looking like a leaking intake valve in the lower left photo?
    I own/have owned Lycoming, Continental, and Rotax. They seem to all have their quirks. The Rotax, being that it isn't a century old design, has a learning curve to it that's for sure. Awesome engines when they are running right. Fuel efficient and pretty reliable.
    The S-7 I purchased several years ago had been run on 100LL almost exclusively. It used oil at a high rate so I removed the cylinders for replacement with a 'Zipper' kit. The valves, and rings were quiet loaded up with carbon and other grud (lead buildup?). I prefer to run 91 non-oxy, as designed.
    Don't take life too seriously ... no one gets out alive!
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,036
    I've burned a total of 15 gallons of Avgas I'm my Rotax, I n 2900 hours, and....a, fair amount of E10 when no E0 is available on a XC. No issues with any of it, and valves/ plugs look great.
    Likes mixer liked this post
    aktango58's Avatar
    18AA
    9,711
    Nice when you can run on what the engine was designed. A gas engine will run (sort of) with a bunch of diesel, but don't put gas in a diesel.
    Feb 2004
    Mt.
    1,345
    [QUOTEA gas engine will run (sort of) with a bunch of diesel, but don't put gas in a diesel.[/QUOTE]
    Most diesels will not even fire on 100% gas in my experience but just a touch of diesel will destroy a aircraft engine in seconds due to extreme detonation. The amount of #2 diesel in the hose of a 2000 gal delivery truck cost the Bulk Distributor a TSIO-520 continental in a Cessna Ag-Husky here years ago and changed the way AVgas is delivered here to dedicated equipment.
    Thanks EdH thanked for this post
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,036
    I tried running gas in a old Mercedes 190D once (an oopsie at the pumps, not on purpose. Full tank, made it up the onramp before it slowly died. No drama, once reprimed with the proper fuel and the tank drained and filled, it ran normal.
    Likes mixer, OzAK liked this post
    Jan 2017
    Utah/Alaska
    363
    Who did your overhaul at 2400?
  1. Just bought a J3
    By greenhorn in forum Cafe Supercub
    Last Post: 11-05-2010, 08:56 PM
  2. Bought a Bonanza
    By 3689A in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 11-28-2008, 02:03 PM
  3. Looks like I bought a airstrip.....
    Last Post: 08-07-2006, 11:46 AM
  4. Almost bought the farm
    By JoeW in forum Cafe Supercub
    Last Post: 07-07-2004, 08:15 AM
