Page 1 of 2 12 LastLast
Results 1 to 40 of 41
Thread: Concerned about some corrosion on tubes
    Jun 2021
    25
    I recently bought this cub and noticed some corrosion on the X brace and a couple other tubes in the cockpit. Everything else looks fairly clean but these spots are showing some clear signs of corrosion. It kind of looks like some of the rust was painted over at one point as well. It's going in for its first annual next week and I'm a little worried about what might come of this. Just trying to budget for the annual bill, anyone have any idea if this is something that can be cleaned and protected or am I looking at a major repair with replacing these tubes?
    In one of the pictures you can see I cleaned a small spot of the rust off, it wasn't deep but the tubes definitely have some minor pitting left behind from the rust. :/
ID:	58126   Click image for larger version.
ID:	58127   Click image for larger version.
    11,810
    That does NOT look like "Minor" rust to me. A little hard to tell for sure from photos, but that would spook me. And, in any case, I'd REALLY want to know what the rest of the frame looks like.
    Where was this plane before you bought it? High humidity/coastal area? Do the logs offer insights? Do you know who rebuilt it last? Etc.
    Jun 2021
    25
    All I know is it was hangared in northeastern Pennsylvania. Logs don't offer any insights. :/
    RCharles's Avatar
    Jan 2004
    Atlanta, Ga
    283
    When was it built and is there rust showing on the fuselage lower tubes any where?Check the tail group carefully.If you see any brown stains on the fabric inside the fuselage along the longerons then I would say find yourself another plane! That is from personal experience...
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    868
    Rust never sleeps. You own the airplane so keep after it. A little elbow grease, primer and paint goes a long way. The lower longerons are critical to inspect.
    9,711
    Hard to tell, but looks like some of the gingerbread also has corrosion.
    Not that hard to deal with that area, though you might end up pulling the skylight to really get it Clean.
    What I would be concerned with is having that much corrosion up high where it doesn't get wet, and wondering how much corrosion is on the lower part of the plane where it really gets wet?
    As your mechanic though. Let him guide you as it is his signature on the line. Also, he can touch it, and inspect it, and make a determination.
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    949
    A prick punch and small hammer spent tapping every, 6/8" up "every one of the lower longeron's"; will tell you awful fast, spend extra time around gear fittings. It ring right out
    if it's solid. If they are half rotten thru they will sound flat and punky................ If they are 80% or more corroded from inside the punch will go right thru or dent the tube. This was standard procedure 30 years and NO ONE would have
    purchased without doing this test on any rag/tube airplane
    Some modern day mechanics will talk about the tiny spot
    the prick punch leaves......... Say a .030 spot. Could start coroding after the test. So simply take a small brush and put one tiny drop of paint/dope on the spots. Done.
    If it has longeron's that are rusted better plan on $20k to
    Replace em in today's market. Your surface rust on the overhead stuff will seam pretty minor if your longeron's are shot!
    Good Luck
    E
    Jan 2016
    67
    Concur with the posts above especially #6, was that aircraft ever a banner tow? Or live outside in Florida? Corrosion up high like that is a tell tale sign it flew in humid salt air.
    jrussl's Avatar
    Jul 2005
    Madison, WI
    685
    Make sure to check behind the channel on the rear door post.
    Everything looked good on this one until the channel was cut off.
    Likes Hardtailjohn, Pete Schoeninger liked this post
    behindpropellers's Avatar
    NE Ohio
    6,994
    Are those LED lights glued to your tubing?
    Mar 2016
    1,830
    To my eye, those pictures show the tubes were repainted over existing rust and other crap. I would hate to see what is back there the fabric wraps the tubes.
    Regards, Charlie
    21,489
    What does the tail look like? Remove the battery cover or baggage aft panel and look. Seen corrosion on the cockpit tubes from people grabbing the tubes and over time rubbing the paint off.
    May 2017
    1,212
    Combined with salt from sweat on ones hands.
    Jun 2021
    25
    Yeah the previous owner put them on. It's an E/AB cub and that was his solution to night cockpit lights.
    Jun 2021
    25
    fortunately it's easy to see the tubes in the back, my cub doesn't have a cargo headliner installed so you can see everything back there. I didn't notice it until after I bought it but the tubes are painted two different colors of grey. This dark grey was the paint put over the corrosion and there's a light gray that was the original. Everything in the back is still the light grey and looks pretty good. I found two small spots of concern but the lower longerons look pretty clean and I've combed every inch of the aft structure with no big issues. Which is why I find it odd that this structure up high is what got corroded.
    Jun 2021
    25
    Steve, aft looks pretty good. I found two spots where paint had chipped off the tubing and started to corrode, but everything looks pretty clean back there. It's all the tubing in the cockpit including places you could never grab that corroded. Seems very counterintuitive that the tubes up high are corroded but not the tubes down low?
    3,201
    heated humid air rises - clouds - until it condenses on something cooler like tubing. If the top of the cockpit is somewhat sealed to venting it gets worse. I've seen it in vehicles and airplanes particularly in winter.
    7,678
    My J3 had pretty good rust on those "handhold" tubes in 1962. Cleaned it up, painted the whole frame in epoxy (cheap back then) and pressed on. No problems since then.
    Jun 2021
    25
    Quote Originally Posted by jrussl View Post
    how does one check this without cutting the channel off. Mine looks good on the aft side but can't see the front side. Would hate to cut that piece off just to inspect there?
    That said, mine is an EAB cub that the builder modified the door so that post slants down and aft to make the door larger. The channel is not welded at the bottom and looks like it allows for moisture to drain out, if I recall from Steve Pierce walking through the annual on the YouTube videos he mentioned this post is a typical corrosion culprit because it's sealed at the bottom and collects moisture?
    Jun 2021
    25
    I discovered the culprit after some more digging in the logs today... can't believe I didn't catch this before I bought it but it did spend six years in Florida on the Gulf coast, and in those six years it was annualed one time. And there were six or seven hurricanes that went through too. God I hope it wasn't just sitting out on the ramp that whole time. Can't believe I never noticed this.
    Jun 2021
    25
    Well unfortunately I found this as well. I've inspected the entirety of the lower longerons and everything else still looks decent. There's no evidence of any corrosion on the bottom side, and I went along the length doing a tap test. It all still seems solid except for this one spot. It looks like I'll have to cut the belly open to get to this spot, which I figure if I'm going to do that, I may as well get the metal belly kit from Univair. Anyone have any experience putting one on an already skinned plane? Is that a worthy investment?
    21,489
    NE Ohio
    6,994
    I think Steve left this picture out:
    Likes RaisedByWolves, Hardtailjohn liked this post
    21,489
    Actually the last two I drilled, a 1979 and a 1982 were not rusted.
    WhiskeyMike's Avatar
    West Boxford MA
    990
    Quote Originally Posted by Globemaster View Post
    My guess would be: Hands on the windshield area cabanes leads to minor corrosion. You almost always see that. Upper cockpit, probably had water seep in under the skylight after sitting in the rain. Plane not flown,not dried out. Lower fuselage, water settled in.
    Chances are you can deal with this, but I'd strongly recommend you stay on top of it. It's not just a one time fix. You better have a darn good look at the struts and fork fittings. We used to weld in bushings to add Bradley safety straps between the fuselage fork fitting and the strut before sealed struts became available. On one occasion, we drilled the strut for the bushing near the fork and a quart of water came out. The fuselage probably won't fall apart but if a strut fails, it's all over - and it has happened more times than people generally know about. You should also check the lower tail brace wire fittings at the fuselage. Best of luck, Be careful.
    Jun 2021
    25
    Quote Originally Posted by WhiskeyMike View Post
    Yeah I figured I have some consistent work ahead of me. I'll be moving to Alaska in a couple years and when I finally get it up there my plan is to tear it down and build a new so it just has to last me until then haha. I already ordered new sealed struts for it, should be finished up at Airframes this week and I'm planning to buy all four new tailbrace wires as well. They weren't pretty and I noticed someone painted them with silver paint to hide the corrosion.
    Jun 2021
    25
    Steve,
    After reading through post #25 and seeing what the channel looks like on other cubs I'm going to remain hopeful. It looks like mine was built to allow it to drain any moisture inside it. (Will post a picture later.) That said I'll probably still have them drill in to it like you did. It's a '98 so hopefully it hasn't had long enough to look as bad as some of the ones you found!
    supercrow's Avatar
    Dec 2008
    572
    Hate to be a party pooper, and it is probably just me, but I would tear it down and start over. Not worth the grief, and you "will" find other problems. Sorry, just my 2 cents.
    Jun 2021
    25
    Quote Originally Posted by supercrow View Post
    That is the plan, but at the moment I can't afford that, and I'm getting ready to head off to a year and a half of USAF pilot training so I wont have time to work on it that much. After training I'll be moving up to the Anchorage area, once I get there my plan was to tear it down and start over. I just need it to last a couple more years. *fingers crossed*
    Likes supercrow liked this post
    11,810
    Not to toss even more cold water on your parade, but when you get to Alaska is precisely when you're going to want a flyable airplane, NOT a project. I understand your constraints, as you've explained, but I'd sure try to figure out how to get the thing ready to rock as soon as you arrive in AK. "Project" airplanes can take FOREVER to complete, and while Alaska winters are long, there's still a lot of flying to be done. Trust me, THAT's when you'll want a toy to go play with, as opposed to a "project" to go work on!
    Likes jrussl, Hardtailjohn liked this post
    3,201
    How about asking around for an A&P that's dealt with corrosion? Ask them to pick and poke the usual suspects for damage. Then you'd know if it's airworthy. Better to know and get it fixed than wait.
    Jun 2021
    25
    Oh I agree, that's the reason I got the cub in the first place. Unfortunately I just can't take on a restoration project while I'm in pilot training and Alaska is where my buddies are that can help me restore it.
    It's a pickle for sure... At least I have a 10 year contract with the Guard in Anchorage so I've got lots of time once I'm up there haha.
    Jun 2021
    25
    The shop I'm trying to get it in to just got done fixing some corrosion on a Pacer so they are freshly experienced haha. They are going to look at it this week and give me a verdict. That's the worst part of this whole thing is waiting for an answer haha.
    3,201
    Good you found a shop with experience. I hope it gets resolved favorably and safely for all. You will enjoy Alaska and have the right plane for exploring.
    11,597
    Pictures don't give the full answer. Are those cracks next to the vertical tube on the longeron? Since your plan is to do a major do-over when you get to Alaska, this can just be done with a local repair. Cut open the belly fabric enough to peel the fabric back for access. Fix what needs fixing, patch the belly fabric, reshrink, paint ...done. Forget the metal belly.
    Jun 2021
    25
    Thats fair, maybe the metal belly is a little over doing it at this point. My thought process was to use this as an excuse to inspect the longerons even better than what I've been able to do so far just to be extra sure there are no more corrosion spots I'm missing. I suppose that could be over doing it too... just being a first time owner worry-bee? Haha I will say I thought my cub looked decent compared to a couple Cubs I saw at Airventure this summer. Lol
    21,489
    Steve,
    This is a 1998 model year Super Cub?
    Jun 2021
    25
    Affirm, it was built new in 1998, from what I can tell it was built to match the standard -150.
    Jun 2021
    25
    Here is the after door post, it looks like the bottom is not sealed and allows water to flow out. Not 100% sure though.
    Jan 2008
    Arlington, WA
    868
    Pretty rough looking fuselage. Did the builder do it himself or use an old airframe?
  1. Corrosion 47 PA-12
    By utb 44E in forum Super Cub Sick Bay
    Last Post: 06-06-2018, 01:58 AM
  2. Corrosion
    By CubDriver218 in forum Cafe Supercub
    Last Post: 07-26-2014, 07:02 PM
  3. Replies: 0
    Last Post: 03-04-2013, 01:03 PM
  4. electrolytic corrosion
    By JimC in forum Super Cub Sick Bay
    Last Post: 10-11-2007, 12:13 PM
