Cessna 185F fuel pump microswitch
ron
Wanaka,NZ
I wish to replace the low pressure booster pump microswitch on our C 185F.Printed on the switch is 12SE1-3.Anyone know where to purchase one of these please.Thanks.
Do a Google search, multiple sources. 'Onlinecomponents.com' shows seven at Honeywell.
Just a tip for the Cessna guys; all those little electrical components are easier to find in the wiring diagrams, in the maintenance manual, than in the parts book.
Thanks wireweinie.That is the correct microswitch.Mounted on the microswitch body is a stainless steel arm with a small roller at the end.The roller runs on a cam at the end of the butterfly arm.All that is printed on this component is Micro j2-5.Sorry cannot seem to get a photo on this site.
If the arm is serviceable just install it on the new switch. It's just held on with the switch mounting screws.
Here are some clips from the book. Look at part #52.
  • pic.pdf
  • Switch.pdf
You have been very helpful wireweinie,I misread the number.Have you any sources for the JE-5 please.Nothing available here in New Zealand!
I see they have the switch as well at online components.I will get both online.You have been a great help.Perhaps you could come to NZ and fit it for me for a small charge!
Do you need the switch and the actuator?
Never been to the south side of the pond. Hope to get there one day.
