Results 1 to 8 of 8
Thread: Best location to instal fuel boost pump IO360 PA18
    Dec 2018
    94
    Iím fitting an IO 360 to a PA 18. Any ideas or pictures on best installation position for airflow performance fuel injection pump. Ideas and suggestions appreciated with pics if possible.
    stewartb's Avatar
    Wolf Lake, AK
    6,580
    API suggests installing inside the cabin to keep it out of the heat. I didnít want a fuel pump inside so itís mounted on the lower right side of the firewall inside a sheet metal box thatís interior is cooled by a blast tube. The front is secured by a couple of quarter turn fasteners. It works great. No hot start issues.
ID:	57807   Click image for larger version.
ID:	57809   Click image for larger version.
    Thanks Lowleveldevil thanked for this post
    Likes Lowleveldevil liked this post
    stewartb's Avatar
    Wolf Lake, AK
    6,580
    Are you using their fuel filter? I didn’t and I wonder if I should. Fuel goes through a Steve’s gascolator before the high pressure pump so hopefully that’s good enough. I’ll add a pump on indicator light in the panel this winter. I forget to use the pump for takeoff and landing more often than not.
    11,477
    Difficult to see. The Whelan pump is located just under, slightly ahead and outboard of the fuel selector.
    stewartb's Avatar
    Wolf Lake, AK
    6,580
    Don’t forget to plan for a fuel pressure gauge, which means putting a sender unit in the fuel line after the mechanical pump. I didn’t do one initially and added it later. It would have been easier to install at the start.
    Dec 2018
    94
    Yep I had planned to fit one thanks again Stewart really appreciate your input
    stewartb's Avatar
    Wolf Lake, AK
    6,580
    Well, I finally ordered an indicator light for the electric fuel pump so thanks to you for bringing the topic up!
    Dec 2018
    94
    Haha my turn to help you
  1. IO360 A1A fuel servo
    By bodumatau in forum Experimental Cubs
    Last Post: 12-10-2019, 05:09 PM
  2. Boost pump for Smith Super Cub - Should I or not??
    By GeneHerzog in forum Experimental Cubs
    Last Post: 02-14-2007, 10:19 PM
  3. Wheel ski pump location
    By TerryH in forum Modifications
    Last Post: 08-12-2004, 08:59 AM
