Results 1 to 11 of 11
Thread: Wag 2+2 project
    Sep 2021
    Missoula MT
    4
    Wag 2+2 project
    Just bought sportsman 2+2. It comes with welded fuselage, wag tail group, flight controls, doors with hinges, pa 18 gear, tires and wheels, wood wings put together, flaps and ailerons put together. Nothing is covered. I also believe it comes with all of the cowl/floor aluminum. Never been registered. I am hoping the 51% rule won’t be an issue.
    Likes pzinck liked this post
    acroeric's Avatar
    Nov 2005
    Burlington, NC
    125
    Get a copy of the FAA Amateur Built Assembly and Fabrication Checklist. Your DAR will want to see it when it's complete. Should be easy to see what % you can claim for the remainder.
    1,168
    Quote Originally Posted by acroeric View Post
    The checklist is the best starting point. If the previous work (done by prior owner) was done for education and entertainment, it also counts towards the 51%. It doesn’t all need to be done by the final builder. Airplanes can pass through any number of owners, but as long as all the work was for education and entertainment, it all counts.
    The only things that dont count are things that were done as commercial assistance, or purchased completed components.
    Dec 2009
    Michigan
    126
    .........Airplanes can pass through any number of owners, but as long as all the work was for education and entertainment, it all counts.
    I agree with the post above. I'll add that You will need evidence that the previous that the project was "amateur built for the purpose of recreation and education" You should have gotten the previous owners builder's log to show this evidence. Photos with an amautre doing something is also good evidence.....reciepts, etc.
    May 2021
    Arizona, USA
    315
    Assume an EAB aircraft was constructed over a period of time by several different builders each of whom sold the project to the next builder. The final owner who completes the build had no involvement with the earlier build tasks.
    What percentage of the final build must the final owner perform in order to qualify for the repairman certificate?
    Can the final owner who completes the build qualify under any circumstances for a repairman certificate?
    RVBottomly's Avatar
    Sep 2017
    1,254
    It is undefined, but you have to be the "primary builder."
    Here is a short reference article on it: https://www.eaa.org/eaa/aircraft-bui...an-certificate
    May 2021
    Arizona, USA
    315
    That reference seems to conveniently ignore the eligibility requirements of FAA Order 8900.1 Vol 5, Ch 5, Sec 5 para 5-1219 A. 2).
    "An individual working alone who applies for a Repairman Certificate (Experimental Aircraft Builder) must build the majority of the aircraft to be considered the primary builder and to be eligible for the certificate."
    http://fsims.faa.gov/PICDetail.aspx?docId=8900.1,Vol.5,Ch5,Sec5
    RVBottomly's Avatar
    Sep 2017
    1,254
    That reference seems to conveniently ignore the eligibility requirements of FAA Order 8900.1 Vol 5, Ch 5, Sec 5 para 5-1219 A. 2). "An individual working alone who applies for a Repairman Certificate (Experimental Aircraft Builder) must build the majority of the aircraft to be considered the primary builder and to be eligible for the certificate."http://fsims.faa.gov/PICDetail.aspx?docId=8900.1,Vol.5,Ch5,Sec5
    Well, good find. Looks like all the info is in that order.
    Sep 2021
    Missoula MT
    4
    Thanks for the feedback, here are some pictures that better describe what I have. Name:  7EED2E96-FFE0-490D-BEF1-B4997D78E15B.jpeg
Size:  28.1 KBName:  393954A5-4463-4CA0-8770-B0A99DCF6124.jpeg
Size:  26.6 KBName:  D7061049-767F-439C-8622-3E2F470B04A6.jpeg
    RVBottomly's Avatar
    Sep 2017
    1,254
    You certainly have a project! Looks like you have nice tires, too.
    Try to get the prior builder's build log. Then get the FAA homebuilder's checklist for percentage of each task/component. You might still be able to account for 51% of the build. Then you'd be eligible for the repairman's certificate, too.
    I can't tell from the photo, but it looks like you still have welding to do for tabs, pully mounts, fabrication of cowling channels, etc.
    Also, I hope the fuselage is painted brown rather than covered with surface rust.... if it is, that is the first thing to deal with. I'd prefer a different color so that rust would be easy to see if it shows up.
    Good luck! I have a 2+2 project that is about that far along and I think I have more than halfway left to go.
    1,168
    There is no minimum participation by the “final” builder. Remember that on the 8130-12, the names of ALL builders should appear.
    Now, in order to qualify for the Repairman Certificate, FAA will want to see evidence of significant participation, but I don’t think there is any specific guidance, just up to the Inspector based on an interview with the applicant.
    Don’t confuse the “major portion” required for the Airworthiness Certificate, and the requirements to qualify for the repairman certificate. They are very different requirements.
  1. looking for a project
    By mike mcs repair in forum Everything Else
    Last Post: 09-25-2018, 07:30 PM
  2. J5 Project
    By J5Ron in forum Member Projects in Progress
    Last Post: 04-29-2018, 01:31 AM
  3. New Project
    By brokemx in forum Experimental Cubs
    Last Post: 06-05-2014, 11:26 AM
  4. Another Project
    By Glenn5ft19 in forum Cafe Supercub
    Last Post: 10-12-2010, 02:03 PM
