Thanks Thanks:  0
Results 1 to 4 of 4
Thread: Federal AWB2500 Wheel/Ski W&B
    Dec 2014
    28
    Looking for some examples of W&B for a Cub on AWB2500 Wheel/Skis extended and retracted. These would be on an Experimental Cub. Any members familiar running these on a Cub?
    Steve
    11,746
    Are pretty big for a Cub, but.... Mine weighed upwards of 120 pounds for the whole setup. You should have two weight/balance documents when aboard, one for skis up, one for skis down....changes CG position.
    Dec 2014
    28
    Yea, I'm trying to figure out the numbers for Skis down,, the logbook shows weighed with skis on, but the down ski W&B has the same weight and moment as the up ski W&B,, should the arm not move when the skis are down changing the weight and moment?
    This set, has been flown on this Cub for 30 years, I recently started flying it and when I reviewed the old W&B I discovered the numbers did not seem to be correct. Documents for these seem to be difficult to source. The Cub is a 2K Cub.
    Steve
    11,746
    Quote Originally Posted by stid2677 View Post
    Yea, I'm trying to figure out the numbers for Skis down,, the logbook shows weighed with skis on, but the down ski W&B has the same weight and moment as the up ski W&B,, should the arm not move when the skis are down changing the weight and moment? Depending on the arms, those things probably move 8 to 10 inches....maybe.
    Steve
    Yes, when you extend the skis, they move aft, though not quite as much as the Fluidyne 2200s do. But, enough that it'll change the arm a bit....and in the aft direction.
    When the skis are down (ski position, they are pretty close to centered on the axles, so I guess you could use that as the location of the skis for the ski position. Then, maybe retract the skis and measure how much forward that point moves.
    Sorry, I no longer have the logs for the plane my set was mounted on. But, I do remember different CG for skis up and down.
    Likes stid2677 liked this post
  1. Federal AWB 1500A's Wheel Skis
    By intheair2 in forum Cafe Supercub
    Last Post: 09-06-2008, 03:40 PM
  2. Federal 2500 Wheel Skis
    By cubnut in forum Cafe Supercub
    Last Post: 06-30-2004, 02:01 PM
