Results 1 to 16 of 16
Thread: Vinyl Stripes on a Cub?
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    320
    Has anyone used 3M or other vinyl striping on a Cub. Iíd like to run a black 1/4 inch strip on the current project but Iím interested in opinions on the matter first. If I donít use vinyl, itís going to be a lot of work to mask for paint in this instance.
    PA-12 N418BS
    gbflyer's Avatar
    Feb 2007
    PAGS
    767
    Not a cub but on Superflite fabric I have. Works great! May not last as long as paint if exposed to weather full time. Not sure. Pretty easy to apply.
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    394
ID:	57798vinyl striping on a Cub
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    394
ID:	57799vinyl striping on a Cub
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    320
    I’m curious if during installation if you can remove it as long as it not pressed on too hard. Sometime it take a couple of try’s to get it perfectly straight. Any brand recommendations?
    PA-12 N418BS
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,036
    I have had vinyl lettering done on 5 different boom trucks, and the stuff holds up so good I'd have zero qualms about using it on an airplane. BUT...I'd get, if I was putting it on my plane, my buddy who owns the sign shop and works with the stuff every day, to do the application, just like I did with my trucks. Get someone who does it all the time, don't learn on your bird, it is money well spent (and shouldn't be much anyway) and this is coming from a cheapskate!
    Likes stid2677 liked this post
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    400
    Quote Originally Posted by KJC View Post
    Yes, CubCrafters uses vinyl for stripes, logos, numbers, rudder checker board, and probably other trim areas.
    Thanks ak-flyer thanked for this post
    Aug 2003
    1,393
    Aerographics, Loveland, CO. They supply to many high-end warbird, acro, and fabric shops. They've got way more designs than shown in the online catalogue, plus clear directions that even I can follow. They're used to dealing with aviation-specific questions and issues, which may not always be the case with a local sign shop. And yes, I've done a fair amount of masking for paint designs, but difficult to justify the time to get it "just right".
    http://www.aerographics.com/index.php
    Thanks. cubscout
    supercrow's Avatar
    Dec 2008
    572
    I have some out that is over 25 yrs old and looks great. Best material available and put on by those in the know. Makes a great looking job with very clean lines as compared to some paint lines.
    gbflyer's Avatar
    Feb 2007
    PAGS
    767
    Iím curious if during installation if you can remove it as long as it not pressed on too hard. Sometime it take a couple of tryís to get it perfectly straight. Any brand recommendations?
    In my experience, itís so thin that once it touches dry its over. You can spray the surface with a weak soapy water solution (a few drops in a spray bottle) and slide the graphic around. Then squeegee out the soapy water.
    Upper Peninsula of Michigan
    714
    3M striping and lettering. I used the soap water squeegee method. Very easy. It can be easily removed with light sweep of heat gun if you mess up. I designed lettering on diylettering.com
    Likes Hardtailjohn, Southern Aero liked this post
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    320
    Having never used the stuff, I’m a bit confused. Is it more than just an adhesive backing on the tape? What’s this soap and water squeegee method you speak of? Also, do they shrink after several months on the plane?
    PA-12 N418BS
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,036
    Local sign shop, no need for a aero specific provider. Have them put it on in exchange for a ride!
    Grant's Avatar
    At Work.....
    1,961
    If it is done correctly it looks great.
    714
    It’s adhesive with backing tape, but the water trick allows positioning it to exactly where you want it then squeegee the water out….it works fantastic. The sign shop even said if I messed up they would send replacement letters and numbers free…just pay shipping. I bought a pretty big roll of each color striping because I’m going to strips my floats the same way. No shrinkage or peeling….I glanced over it very lightly and carefully with a heat gun in spots I thought might be more apt to lift. Ver very cafefully.
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    320
    Thanks everyone. I’ll be making some phone calls today.
    PA-12 N418BS
  1. Orginal Super Cub Stripes + Decals
    By ron in forum Super Cub Repair Facilities
    Last Post: 01-27-2019, 11:53 AM
  2. Wing Stripes
    By tamarack in forum Cafe Supercub
    Last Post: 11-29-2009, 08:49 AM
  3. sliding window stripes
    By Fido in forum Cafe Supercub
    Last Post: 01-04-2007, 11:25 PM
