Results 1 to 17 of 17
Thread: Plans for wood wings?
    Oct 2021
    6
    Does anyone build experimental category cubs with wood wings?
    Are plans for wood wings available?
    Thanks!
    RVBottomly's Avatar
    Sep 2017
    1,349
    Any of the Wag Aero plans show wood wings. Iím building a 2+2 with wood wings right now.
    Nov 2019
    Kalispell, Montana
    53
    I’m building aluminum wings for my SC clone right now. I have a box of steel hardware for wood wings if you are interested.
    RVBottomly's Avatar
    Sep 2017
    1,349
    Quote Originally Posted by Farmer Hank View Post
    I'm still interested. My original plan was to fly over there and look at your goodies. These days, though, I can rarely get more than 3 hours away from home.
    Oct 2021
    6
    [QUOTE=RVBottomly;811824]Any of the Wag Aero plans show wood wings. Iím building a 2+2 with wood wings right now.
    Great! When I looked at their website I don't see that stated anywhere. I will give them a call.
    RVBottomly's Avatar
    Sep 2017
    1,349
    Quote Originally Posted by Mike von S. View Post
    The plans specify a wood wing, but I don't think they stock wood wing materials anymore. I ended up getting spruce spars from Aircraft Spruce after a long wait.
    Wag no longer carries lift strut fittings for wood, either. They will likely try to talk you into aluminum wings.
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,478
    Thanks!
    I have a set of wood wings for my 2+2. I modified the wings to use stock Super Cub hardware for flaps, and changed the tank bay to use a shear plate rather than the cross brace through the tank. I also added the stock wood wing tip bow; I like the original look. I did drawings with measurements in CAD for the wing layout, flaps and ailerons (all wood). Essentially, I have a Super Cub wood wing. Most everything is on my website, marty2plus2.com My wings are ready to cover, should be starting the covering in the next month or so.
    Marty57
    N367PS
    www.marty2plus2.com
    Oct 2021
    6
    Marty,
    Thanks for this pic and for the link to your builder's log website. I've just started looking through it. This will be very helpful in numerous ways.
    I love the frank discussion of the challenges you've faced, and the solutions you've devised.
    You do nice work!
    Mike
    Thanks Marty57 thanked for this post
    Dec 2021
    14
    Wag Aero wood wings
    I have a set of Wag aero I took off a Wag Aero CUB With ailerions. Also interior , formers, baggage , Ect
    Frank Roy 207-299-6911
    Mar 2006
    canada
    89
    Thanks!
    I have a set of home built wing all metal
    Jan 2022
    1
    good morning
    I have drawings and build videos for the wood wings +wag wood spars, set of built ribs, built ailerons, compression tube material, some new drag wires/nipples, wing tip bows and strut material
    pm me if you are interested for details
    thanks
    rich
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    896
    A question for everyone building wood wings from the Wag Aero plans: I've heard there's a difference in the airfoil between a Wag Aero sport trainer and a Piper wing. Anyone know what the exact differences are or how it affects performance?
    RVBottomly's Avatar
    Sep 2017
    1,349
    There is a difference: the leading edge is somewhat rounder. All other dimensions are pretty much the same. I donít know of performance differences. Others say the Wag wings fly fine, maybe slightly gentler stall, but itís not quantified.
    RVBottomly's Avatar
    Sep 2017
    1,349
    Here is a depiction of the difference. The blue ink curve is the Wag upper leading edge curve.
    The pencil curve is from Piperís specs. Everything else matches within a millimeter.
    Thanks Colorado-Cub thanked for this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    896
    That's great, thanks for the info. Guess I'll just go off the Wag plans then since it doesn't seem like that would affect performance much vs going with a Piper airfoil.
    Colorado-Cub's Avatar
    May 2014
    Buena Vista, CO
    256
    I fly a Wag wood wing and can verify the more-round profile of the leading edge.
    My finely tuned rear end can not discern much of a difference to a J3 wing, but my Wag-11 is fat and goofy which limits an apples-to-apples comparison.
    Edit: I forgot to add I love how my Wag wing flies too, so don't fear the profile difference.
    Likes Crash, Jr., RVBottomly liked this post
    Upper Peninsula of Michigan
    773
    My Ex 11 has wood ribs, except in tank bays and by strut attach areas which are actual Piper ribs. I also have aluminum Piper Spars
  1. Need an expert on wood wings
    By Speedo in forum Super Cub Repair Facilities
    Last Post: 06-30-2016, 01:37 AM
  2. J3 / PA11 Wood Wings
    By Roger Peterson in forum Experimental Cubs
    Last Post: 04-23-2009, 02:26 PM
Tags for this Thread
