Results 1 to 19 of 19
Thread: PA 18 blank instrument panel source
    May 2014
    839
    Looking for a blank 9” tall pa-18 panel.
    thought Wayne Mackey had them awhile back.
    anyone have his contact?
    Or other source…?
    thanks
    Feb 2008
    STL
    274
    Javron, Brainerd,MN
    If you get lost while flying, don't try hail a cop. Pick up the first railroad you find and hug it until you get somewhere.
    Thanks Oliver thanked for this post
    stewartb's Avatar
    Wolf Lake, AK
    6,558
    Atlee’s.
    10,867
    Clyde
    May 2014
    839
    Clyde’s where I got some before, thanks for triggering that memory.
    His contact?
    NoFlaps's Avatar
    Jan 2020
    118
    http://www.cubdoctor.com
    4,132
    If you go with all light weight instruments, get an original panel. If you hang anything heavy in the panel get one from Attlee.
    21,296
    I use to use Clyde's panels and add a double on the back like Piper did on the later Super Cubs. Recently I started using the panel blanks from Univair. Thicker material and the roll over the top like Piper used.
    21,296
    This is a Univair panel compared to a Clyde Smith panel. Univair part number is CSI-1028, 9" tall. The CSI-1025 is 8" tall. Clyde's are .040" 3003 and if I remember correctly Univair are 5052 and I know they are .032".
    4,132
    Mr. Pierce
    How do you cut the holes for the Trig heads?
    21,296
    I have an aluminum template, I scribe and cut and file to fit. Have seriously thought of having a punch made.
    My father who is 83 years old is Mr. Pierce, I bet you and I are close to the same age. I am 56.
    Likes Gordon Misch, Charlie Longley liked this post
    4,132
    Tip of the hat to a pro. And I'm 57, kid. Lol
    Likes Charlie Longley, Gordon Misch liked this post
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,764
    The rolled top edge with a slight bead is nice. I looked hard to find a die set to roll that edge when I replaced the panel in my 18-95, but ended up having to hand form it.
    Aside from the edge, the shop I work for now has a panel pro so I can mill any panel. Not sure it’s faster but it’s nice to layout, cut, coat and engrave.
    McAlpine's Avatar
    Jan 2006
    Barrie, Ontario / Gibson Lake CGL3
    94
    Hi Steve,
    Any pictures of the panel layouts..you have it kind of blocked by the top panel in the pic. What little I can see it looks pretty good with the trigs up top right.
    Thanks, I'm looking for ideas that aren't busy.
    Scott
    21,296
    Quote Originally Posted by McAlpine View Post
    Hi Steve,
    Scott
    Scott, some good layouts here. https://www.supercub.org/forum/showt...54930-Cgr-30-p
    Thanks McAlpine thanked for this post
    McAlpine's Avatar
    Jan 2006
    94
    Great ..thanks Steve. I've never done much metal work so I better order 2 or 3 panels
    21,296
    I have cutouts and play with them on the blank panel prior to cutting.
    Likes McAlpine liked this post
    4,132
    The cutouts are the best way of planning your layout. It gives your brain a solid visual picture of the final product. If you do it right, you'll make a few arrangements before you settle on the layout.
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    300
    Yes use the cutouts and play with them to ensure you have good clearance for everything behind the panel. Unless you plan on having it laser cut, you’ll also need a knockout punch and template from ATS.
    Concept to near completion:
ID:	58003Click image for larger version.
ID:	58004Click image for larger version.
    PA-12 N418BS
    Likes wireweinie, McAlpine liked this post
  1. Instrument Panel
    By King Brown in forum Modifications
    Last Post: 04-18-2009, 10:30 PM
  2. instrument (blank) panel for PA-18
    By cabinflyer in forum Modifications
    Last Post: 12-22-2005, 01:59 PM
  3. J-3 Instrument panel
    By KOZ in forum Cafe Supercub
    Last Post: 01-18-2004, 11:59 AM
