Results 1 to 8 of 8
Thread: Flat-Back PA-11?
    May 2012
    SE Montana
    448
    Flat-Back PA-11?
    Does anyone here have, or know anyone with a flat-back PA-11? Mine is the only one I've ever seen, and i was just curious if this was a factory option, or if it was done at rebuild time somewhere along the way. I can't find anything in the logs about it getting done. The plane was used for spraying back in the 50's.
    3,569
    In Roger Peperell's Piper Aircraft book he describes both J-3s (pp. 47 and 52) that were converted to dusters and sprayers. The pic on p. 52 shows a flat back J-3 duster NC7369H. There are PA-11 pics later from p. 81 on that show Whitaker dusters (N4999H) and sprayers (N5052H) but there's no direct view of the rear fuselage shape. I suppose having a flat deck to flow into the flat hopper bin cover would be a reasonable mod. TCDS A-691 under Items 6** lists several crop spraying and dusting alterations available. Might be part of that change.
    May 2012
    SE Montana
    448
    I'll have to look through the logs again and see what sort of spray system was used, mught have been Whitaker.
    Apparently there aren't too many of the flat-backs out there.
    3,569
    Wouldn't it just be a matter of removing the former that creates the inverted-V of the upper fuselage? Then fabric the flat top over and meld with a flat hopper topper? My PA-18A was done like that.
    May 2012
    SE Montana
    448
    Yes, as far as i can tell, the turtledeck is the only difference.
    WhiskeyMike's Avatar
    West Boxford MA
    1,015
    j-3 A model
    Folks made their own hoppers etc for J-3's or later on used Sorenson tanks. I had a 135 HP modified J-3 that had been a "cut back" duster. No turtle deck at all, but a plywood deck on top of the longerons, behind the rear seat/baggage area to stand on while loading dust or liquid spray. There were quite a few of these around. I don't have a photo of mine, but here is one with the same mod -- Makes you think about how a J-3/PA-18 is actually constructed! Note the hinges on the hopper lid, and the step on the bottom longeron to help the loader jump up on the top of the fuselage when necessary.
    Likes 1934A liked this post
    3,569
    Thanks for the recall of tubing on an -A model vs standard airframe.....I got it wrong and forgot there's additional upper longeron tubing added for the flatback fuselage.
    LisaWi's Avatar
    Sep 2021
    Between Lake of the Woods and Lake Huron
    16
    Quote Originally Posted by WhiskeyMike View Post
    You Tube: "Construction of a Light Aircraft (1943)" 27:23 (Filmed at Lock Haven by the Univ of PA School of Eng..)
    https://www.youtube.com/watch?v=Q6q1VKsTeKQ
  1. Replies: 7
    Last Post: 12-28-2020, 12:34 PM
  2. Turtle back or flat
    By teeweed in forum Modifications
    Last Post: 09-14-2005, 10:37 PM
  3. Flat back 18
    By Wayne Mackey in forum Modifications
    Last Post: 04-29-2004, 07:53 AM
