Results 1 to 7 of 7
Thread: -12 fuselage covering question
    Jul 2020
    5
    Just covered the fuselage with envelope and was not sure about the stitching (if any) on the tail. I saw one that had 2 individual stitches on the uppermost crossmember of the tail but it resulted in serious dimples. The stretched fabric sits maybe 3/4” off the tail frame at that point. Is there any standard? What do you guys do? Thanks in advance-
    Andy
    Likes boarfish liked this post
    11,478
    Leave it as is. There is no chafing and it will produce a bit less drag.
    pittsdriver's Avatar
    Feb 2008
    240
    I usually put 4 in the top rib
    Vans RV7 finished 2008
    Backcountry Super Cub finished 2011
    A&P Aircraft rebuilding, Building assistance
    1956 Supercub complete rebuild
    Likes Paul Heinrich liked this post
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    302
    Four with a full length reinforcing and a two inch tape. Don’t use dollar patches. If you expand the picture, you can see before the tape went on. If you don’t stich it the fabric will drum from the prop wash. That’s why Piper did it.
    PA-12 N418BS
    Likes Paul Heinrich, Hardtailjohn liked this post
    3,900
    I've heard it said that the vert stab stitches pull out no matter what, but I disagree. I don't recall how many I put in, three or four, but they've never pulled out. As stated above, full length reinforcing tape. FWIW...
    Apr 2009
    AK
    229
    I like to double each stitch to prevent aforementioned failure...
    21,306
    I have heard for years from people here that the stitching on the vertical stabilizer break but out of all the Cubs I have inspected over the years I have never found one broken. I stitch them per the Piper drawings.
  1. Covering fuselage
    By Ron B. in forum Experimental Cubs
    Last Post: 01-22-2005, 07:16 PM
  2. fuselage covering
    By Lance in forum Super Cub Repair Facilities
    Last Post: 01-13-2005, 10:56 PM
