Results 1 to 22 of 22
Thread: Stewarts glue removal
    May 2014
    839
    I’m stripping a Cub previously covered with Stewarts, last guy used batting around tank bays and all leading edges. Left lots of glue residue when I removed fabric.
    Any tips on removing old glue?
    tried rubber “pinstripe/decal remover wheel” very slow process.
    Tried 3M adhesive remover, slow.
    Best thing so far is brake parts cleaner in aerosol can.
    Maybe this is payback for all the times I’ve badmouthed Stewarts.
    Any ideas?
    thanks,
    Thanks boarfish thanked for this post
    Jun 2008
    aviation
    35
    Karmic retribution indeed
    I'm thinking if the sheetmetal was so bumpy it needed felt when it was covered last its twice as bad now? Might be easier and more practical to replace the leading edges etc and move forward?
    Rocket
    ok, back to lurk mode...
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    853
    Yep tough stuff. I’ve not seen a chemical that will easily remove it. The rubber wheel or eraser stick is slow but will peel it off
    21,305
    Paint stripper? I have always used acetone on small spots.
    May 2014
    839
    I considered stripper but all wing components are epoxy primed and in pretty good shape. I’d hate to cut into and compromise paint layer.
    Fuselage tubes cleaned up pretty quickly with some rags and brake parts spray, didn’t seem to affect paint. I’ll keep plugging away with that and see what happens.
    Dec 2009
    Michigan
    126
    MEK removes EkoBond, but that might effect the wing component's coating too.
    May 2014
    839
    Ironic that you can apply coatings in your living room, but need a haz mat permit to remove it.
    Definitely tough stuff though!
    I try to avoid MEK anymore.
    Per Steve’s suggestion, I’ll try a little acetone.
    Aug 2012
    In the woods
    853
    It won't touch it
    Grant's Avatar
    At Work.....
    1,933
    Quote Originally Posted by Bearhawk Builder View Post
    It won't touch it
    Acetone will work better than anything I've tried. The only thing that removes it faster is to get a good chunk of it lifted and peel it up, otherwise acetone works best for me.
    Thanks Bearhawk Builder thanked for this post
    Hardtailjohn's Avatar
    Marion, MT
    885
    Just go down and get a sanding belt dressing block from Harbor Freight. Quicker and easier than anything else you'll use.
    John
    Thanks Oliver thanked for this post
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,472
    We did find a product that works nicely to remove the glue; here's a link to the FB post about it a while back. We have it available to order or it may be available locally.
    https://www.facebook.com/StewartSyst...8760335656343/
    It works pretty good at softening up the glue; I used it at Oshkosh between sessions to clean the frames we cover each day.
    Marty57
    N367PS
    www.marty2plus2.com
    Thanks Olibuilt, Oliver, flybynite thanked for this post
    Mar 2016
    1,817
    Yup, saw you using it.
    Regards, Charlie
    Likes Marty57 liked this post
    Jan 2005
    Fowler, Ks
    672
    Wire wheel on drill?
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,472
    Quote Originally Posted by flynlow View Post
    I wouldn't use a wire wheel, it will get clogged up real easy and be pretty hard on aluminum leading edges.. This will work nicely on a drill. You can find these on Amazon and many other places also.
    https://www.autobodytoolmart.com/pro...RoCFWsQAvD_BwE
    Marty57
    N367PS
    www.marty2plus2.com
    Jan 2005
    Fowler, Ks
    672
    I would think a fine wire wheel on a drill would work..
    A pressure washer might be worth a try??
    May 2014
    839
    I tried the rubber wheel on a drill motor, minimal success.
    tried John’s suggestion of using rubber belt sander cleaner, worked well on large flat surfaces. Issue is more delicate surfaces - ribs, tank bay edges etc..
    to Marty’s suggestion, found an aerosol product appropriately named “aircraft decal and adhesive remover” at the auto parts store right next to “aircraft paint remover”
    worked better than anything else I’ve tried. I think the key is using a “jell” product that loiters a bit vs something that flashes off quickly (acetone, brake parts cleaner etc..)
    Im thinking laquer thinner may work well too but don’t have any.
    thanks for suggestions!
    doug
    3,899
    I've used lacquer thinner, and it works - sorta. Like you say, flashes off quickly. Stewarts glue is one tough glue.
    Mar 2016
    1,817
    I have an inline air tool that takes a variety of 100mm wheels, wire, solid rubber and segmented rubber are my common wheels, the segmented rubber is the best when dealing with heavy buildup.
    I also have a solvent that does not flash off quick that works well, need to find where it is hiding. It is a decal remover designed for vinyl graphics that we needed to rotate through on race cars.
    Have not used these in a decade since we no longer travel the country to races.
    Regards, Charlie
    May 2014
    839
    Anything that generates heat (friction heat) tends to make a mess with the glue. Thin aluminum skins heat up quickly with eraser disc on drill motor.
    jimboflying's Avatar
    May 2005
    611
    Some formulations of auto gas attack the glue so there must be a chemical solvent that would work.
    May 2014
    839
    A car detail buddy dropped this stuff off.
    By far surpasses everything I’ve tried.
    I put some in a plastic spray bottle, misted an area of glue, waited about a minute and wiped it with a Terri cloth rag.
    glue rolled up and came off in chunks and does not gum up the rag.
    tank bay rib
    One wipe with rag
    second wipe
    Product:
    Thanks Steve Pierce, CharlieN, Bearhawk Builder thanked for this post
    fancypants's Avatar
    Jan 2011
    IL
    418
    If you feel like mixing up your own potion, the SDS lists Xylene and Naphtha
Name:	Screen Shot 2021-10-03 at 10.48.29 PM.png
  1. Stewarts glue removal
    By Oliver in forum Tips and Tricks
    Last Post: 05-19-2020, 02:29 PM
  2. Stewarts Glue with Polyfiber
    By tcraft128 in forum Experimental Cubs
    Last Post: 09-04-2012, 11:44 AM
  3. Glue Removal Help
    By lowandslo in forum Cafe Supercub
    Last Post: 04-07-2004, 08:20 AM
