Results 1 to 13 of 13
Thread: Javron PA-12
    pittsdriver's Avatar
    Feb 2008
    240
    Javron PA-12
    Finished this Javron PA-12 experimental this last spring. Have 45 hrs on it and it is really a great airplane. ECI O-360, 3" extended gear, Acme Black Ops suspension, T-3 tailwheel, Performance air fowler flaps, square tip wing, 84/44 McCauley prop, 26" Goodyears, Swing up doors, extended baggage and more. 2300lb gross weight 1233lb empty. Performs exactly like a Supercub but a lot more comfortable with wider cockpit and legroom. With the Performance Air flaps i can drop it in exactly where I want. Great airplane and will be for sale soon as owner lodt medical.
ID:	57620   Click image for larger version.
ID:	57621   Click image for larger version.
ID:	57622   Click image for larger version.
ID:	57623   Click image for larger version.
ID:	57625   Click image for larger version.
    Vans RV7 finished 2008
    Backcountry Super Cub finished 2011
    A&P Aircraft rebuilding, Building assistance
    1956 Supercub complete rebuild
    acroeric's Avatar
    Nov 2005
    Burlington, NC
    125
    I understand the weight limit is going to increase rather dramatically soon for operations as a Sport Pilot. Rumor has it it could happen as soon as Oshkosh 2022. This would be well within the limit I am hearing about.
    Sep 2016
    144
    Did the match the AOI on this to match the wing AOI on a PA-18?
    Feb 2008
    240
    Yes it did. I built a Javron PA-18 last year and both airplanes have identical engines and empty weight is within a few pounds. They fly identically as i have flown them back to back. I would take this airplane any day over a PA 18 as it has a really comfortable cockpit. If I do another one the only change I would make is todo the aileron cables like a Supercub and get rid of all the monkey motion of the 12. With all the pulleys and changes in direction on the 12 the ailerons are noticeably heavier.
    Likes Gordon Misch liked this post
    stewartb's Avatar
    Wolf Lake, AK
    6,575
    A few years ago I asked Jay if he’d adjust a -12 to PA-18 AOI. He said no. I probably would have bought one if he did. These days a local Alaska guy is building 3-place Supercub airframes.
    Sep 2004
    Illinois & Wisconsin
    841
    Beautiful workmanship. I really like the simple panel design. The removable breaker panel is invaluable for saving backbreaking labor behind the panel.
    Leaving the final paint design to a new owner is a smart idea. The paint scheme is such an individualized decision that can ease or obstruct a sale.
    What do you expect it should bring? I’m still struggling to correctly price my 12 replica.
    Jan 2017
    Utah/Alaska
    362
    What is empty weight?
    Sep 2019
    6
    How much is he asking for the Javron 12?
    Feb 2008
    240
    Empty weight is 1233 and asking price is $190,000. Everything is brand new and has 50hrs on it. Owner lost his medical.
    Sep 2004
    841
    Where is the plane located? I would like to compare our two airplanes side by side.
    You’re spot on with pricing. We need more exp. PA12 owners to start pricing our planes closer to what they actually cost to build and that reflects their outstanding performance and comfort.
    Feb 2008
    240
    Quote Originally Posted by Paul Heinrich View Post
    I'm in Twin Falls, Idaho. Flew it to Idaho City, ID this morning. With two 240lb guys off in around 200ft with no flaps and not really trying and climb 800fpm at 70-75. Cruise is right at 105 true 2550rpm 10gph. I really like the cockpit as it is even wider than a widebody Cub. Has more leg room and the instrument panel is a couple inches above my legs. In a Supercub the instrument panel is almost touching my legs. One thing I will talk to Jay about is making the aileron control cables like a Super Cub and get rid of all the pulleys and monkey motion of the 12. It would make the ailerons a lot lighter.
    Sep 2004
    841
    When and where would you like to meet up to compare our 12s?Click image for larger version.
ID:	57716Click image for larger version.
ID:	57717Click image for larger version.
ID:	57718Click image for larger version.
ID:	57719Click image for larger version.
    Thanks OzAK thanked for this post
    Feb 2008
    240
    When we decided to sell it I told the owner we should leave it white and let the new owner pick his graphics. I have done the last three Cubs in vinyl and it looks as good as paint and is as durable. Here are a couple I did in vinyl.
ID:	57725   Click image for larger version.
ID:	57726   Click image for larger version.
    Likes Paul Heinrich liked this post
  1. L-21 Javron
    By avnxtek in forum Member Projects in Progress
    Last Post: 08-06-2021, 10:37 PM
  2. Javron Cub
    By Cubus Maximus in forum Experimental Cubs
    Last Post: 10-10-2019, 01:58 PM
  3. Javron PA-11 kit?
    By DanP in forum Cafe Supercub
    Last Post: 05-24-2019, 04:40 AM
  4. 200 hp Javron
    By elpcub in forum Cafe Supercub
    Last Post: 04-01-2018, 08:47 PM
  5. Who is building a Javron Cub?
    By Jasperfield in forum Experimental Cubs
    Last Post: 12-18-2014, 10:43 PM
