Results 1 to 24 of 24
Thread: Drilling into spar
    Nov 2014
    Petaluma, CA
    50
    Drilling into spar
    As I turn to messing with the wings in my project, I'm faced with potentially putting some holes in the spar (e.g. pitot tube bracket secured to rear spar and maybe magnetometer mount). This makes me a little nervous!
    The best discussion I found in this area was a series of posts (beginning here) in Bill Rusk's Javron build thread.
    It sounds like I'm ok with generally drilling into spar in the center of the web (equidistant from top and bottom)
    Is there anything else I should be concerned about here?
    Thanks!
    Sam
    stewartb's Avatar
    Wolf Lake, AK
    6,465
    I appreciate your caution and don’t have any “rules” to offer but I drilled my spars in a few places. Every Cub with Atlee Hurricane ties has, too. A few holes won’t threaten the integrity.
    Thanks Sam D thanked for this post
    May 2006
    Wasilla,Ak
    528
    Make sure to deburr any holes made.
    LiteCub
    Mar 2016
    1,801
    I might be a bit different but prefer my pitot tube up front in the jury strut.
    Regards, Charlie
    11,435
    This is mounted on a rib centered between the two spars. I have flight tested it throughout the speed range from 35 up to 155 and it is 100% accurate. Notice the yarn tied to the pitot tube at the high angle of attack. It is straight back at all Angles of attack. remaining within the recommended +/- 10 degrees to the relative wind. I recommend this location for accuracy.
    Edit: It is also midway between the jury struts and the lift strut wing attachments.
    Jan 2017
    Utah/Alaska
    347
    Quote Originally Posted by Litecub View Post
    LiteCub
    Ream them, most drill bits leave ragged holes, I used to work in a fabrication shop. That built parts for boeing. Tim
    21,188
    Outboard of the lift strut is not a high stress area.
    Mar 2016
    1,801
    How far outboard, anywhere near the strut attachment, inboard or outboard is the highest loaded area on the wing.
    Regards, Charlie
    21,188
    Piper's own documentation says you can only splice outboard of the struts. Legend and Dakota Cub wings were tested in DC's wiffle tree with lightening holes outboard the fittings but I don't know how far. Experimental folks should do some testing.
    11,435
    Piper's own documentation says you can only splice outboard of the struts. .
    This only means you and I are only allowed to repair outboard of the struts using Piper's instructions. Piper Service Memo 3a is supposed to cover this.
    A DER would be able to develop repairs in other locations.
    21,188
    Correct, as an A&P/IA I am not going to go drilling inboard from what I see Piper published and what I have learned from talking to Mark at Dakota Cub on the testing of the Super 18 wing and the Legend Cub wing. If I was building an experimental Cub and wanted to go drilling holes I would do some testing. I don't want to be that guy that broke a spar and spiraled down. That sounded very scary to me and I have already survived a midair fall straight down from 100 feet.
    stewartb's Avatar
    Wolf Lake, AK
    6,465
    I remember buying my Cessna’s safety net from Atlee and balking at the idea of drilling the spar carry-through for the Ancra hook bases. He told me not to worry about it, the carry-through was in compression. The same is true of the wing spar. I also remember pics of the lightened early Carbon Cub spars. Do they still do the lightening holes?
    Steve Kracke told me about a wing test for Atlee tanks and how -12 wings flexed up and down inboard of the strut. Not being an engineer type I found that surprising. Further proof that what I don’t know is far greater than what I do know.
    11,435
    True stewart, but the wing spars also have bending loads which the carry-through does not. When the spar is both flexed in bending and loaded in compression at the same time it becomes weaker because it is not as strong in compression while it is bending. I know it doesn't look like a lot, but if it is not perfectly straight the column strength is less.
    What Steve Kracke was referring to was the flexing taking place about the hinge where the struts attach to the wing.
    May 2021
    Arizona, USA
    272
    None in my FX-3 main spar. I don't know what was done in the lower gross weight Carbon Cubs.
    21,188
    I can't remember on the SS either. Here is an FX3 wing.
    stewartb's Avatar
    Wolf Lake, AK
    6,465
    Steve described the flex as a wave that moved full length of the wing. I thought the strut would reduce it. Apparently not.
    3,885
    See figure 18. And superimpose the compressive load inboard of the strut attachment onto this. From https://engineering.purdue.edu/~ce47...amFormulas.pdf
    Mar 2016
    1,801
    Are we talking tiny holes for mounting a pitot tube as the OP was asking that are no more than the rib mounting or are you talking about BIG lightening holes through the web?
    Regards, Charlie
    11,435
    As I recall from an engineer I used to work for, small holes in and near the center of the web are not critical. Big ones like the lightning holes are a different story.
    Nov 2014
    Petaluma, CA
    50
    Good question. Also, I *think* I am ok with the pitot bracket because it appears that it is installed inside the lift strut in the parts manual as shown in the attachment (figure 5 from the parts manual)
Name:	Pitot mount.png
    3,885
    Yes. Note the transverse shear graph referenced above, then add to that the internal shear imputed from the moment diagram. For me, I wouldn't be making big holes without careful analysis or proven experience.
    RVBottomly's Avatar
    Sep 2017
    1,229
    Thanks, Gordon. Something added to my library!
    21,188
    The screw holes for the pitot bracket are in the middle of the web and should be no issue. I tend toi look at how Piper did things and figure it was for a reason and stick to their engineering unless a reputable source proves otherwise. I am not smart enough to engineer on my own
    4,520
    Sport cubs had lightning holes everywhere. Front and rear spar. Carbon cubs do not.
  1. locating correct elevation points of front spar and rear spar .
    By Kahles56 in forum Piper: PA-12 Super Cruiser
    Last Post: 02-14-2021, 02:35 PM
  2. Spar Drilling
    By PA18project in forum Experimental Cubs
    Last Post: 01-05-2014, 02:51 AM
  3. J-3/Wag Aero Wing. Wood spar vs metal spar differences.
    By iflyforpie in forum Super Cub Sick Bay
    Last Post: 10-27-2013, 10:22 PM
  4. One wood spar, one metal spar. Issues?
    By Clay Hammond in forum Cafe Supercub
    Last Post: 05-26-2009, 09:49 PM
