Results 1 to 13 of 13
Thread: Stabilizer Leading Edge
    Aeronut's Avatar
    Dec 2019
    Kittery, ME
    76
    I‘m about to start jigging up the stabilizer of my PA-18 build and the kit presented me with two options for the outboard portion of the leading edge. I can either keep the leading edge diameter the same on the outboard as the inboard or I can flatten the outboard portion to the same thickness as the elevator at that location.
    Does anyone have an opinion of one over the other? If I flatten that portion of the leading edge, what process do you recommend?
    11,430
    Piper drawing #12769 says to flatten starting 6" from the end. They don't say how. You could use a couple of 2x4s squeezed with a big C clamp.
    A3310071.pdf (supercubproject.com)
    Thanks RVBottomly, Aeronut thanked for this post
    Aeronut's Avatar
    Dec 2019
    Kittery, ME
    76
    Ah! I didn‘t realize this was an original piper thing. I‘ll take a look at that drawing. I like the idea of 2x4s and a C clamp.
    11,430
    Take care to squeeze equally on the top and bottom. If you don't the stabilizer, will have a twist on the tip which could effect the flying characteristics. It may not be much, but every little bit counts. Be certain both stabilizers are the same. It is possible to end up with a twist from the tip of one side to the tip of the other. If you end up with a twist on one stabilizer, make sure the twist on the other one is the opposite. Then the twist (error) will offset the other one.
    Thanks Aeronut thanked for this post
    Aeronut's Avatar
    Dec 2019
    Kittery, ME
    76
    Good point, Skywagon! I'm going to put some thought into it and then set up a jig/clamp so that I can get consistency.
    Drawing 12769 states to flatten to 3/8" an area on the outboard portion of the leading through 6". I assume that after 70 years this hasn't resulted in any problems but it does seem like a bit much of unnecessary stress at the transition from 3/8" to 1". I'm plannig on setting it up so that it tapers from 1" to 3/8" if I can get that working.
    I'll try to remember to post pictures on this thread in the next week or two when I have it all set up.
    Thanks for the tips!
    May 2021
    Arizona, USA
    262
    CubCrafters flattens the leading edge. Here is my FX-3 stab as I assembled it in the welding jig:
Name:	FX-3 stab in jig.PNG
    Aeronut's Avatar
    Dec 2019
    Kittery, ME
    76
    I like that taper. I'm going to see what I can to duplicate that.
    Jan 2017
    PNW
    151
    If you have a mill with a Kurt vice on it you can use that vice. Works better than a C clamp. Easy to make a couple tapered wood blocks, one for each side of the tube, and cut the desired tube profile into that. Put the tube between the blocks and smush with the vice.
    Aeronut's Avatar
    Dec 2019
    Kittery, ME
    76
    I do have access to a Kurt vice. I'll need to double check the depth but I think it might even be greater than 1". I like that idea but I think the challenge would be getting both leading edges on the same plane since on a mill it would be hanging off to the side.
    11,430
    Quote Originally Posted by Aeronut View Post
    it does seem like a bit much of unnecessary stress at the transition from 3/8" to 1". I'm planning on setting it up so that it tapers from 1" to 3/8" if I can get that working.
    You can always warm it up with a torch to soften it.
    Mar 2016
    1,800
    A good size bench vise with flat boards works well.
    Put a spacer, dowel, drill bit, metal or wood stock or something at the thin end as a stop to help with parallelism and reduce over compression. You can add clamps as needed to spread the compression easier.
    I am starting my taper at the near rib.
    My outer end is not flat since the rib has an airfoil shape.
    If you have access to a bench press consider that as well. Vises and C clamps are not designed with the proper threads to draw allot of load.
    Regards, Charlie
    Thanks Aeronut, mixer thanked for this post
    Aeronut's Avatar
    Dec 2019
    Kittery, ME
    76
    I like those pointers, Charlie, in particular the one with the spacer. I'll need to incorporate that.
    Aeronut's Avatar
    Dec 2019
    Kittery, ME
    76
    Here are some pictures of the press dies I made to flatten the end of the leading edge. I set up a 3 degree slope on the milling machine and made each half of the die. The intent is to press the tube ends using my end vise. In order to keep the leading in plane I have a tool I made that should allow me to keep the leading 90 degrees to the horizon during pressing using bubble levels. I did a practice run a scrap piece of 1" tubing and I'm pretty confident this will work on the actual piece.
ID:	57872Click image for larger version.
  1. Leading Edge Cuff
    By ksecub in forum Modifications
    Last Post: 02-26-2021, 05:55 PM
  2. Wag Aero — taper flattening stabilizer leading edge ends
    By rv7pilot in forum Experimental Cubs
    Last Post: 11-09-2017, 12:15 PM
  3. Leading edge
    By STEEL in forum Experimental Cubs
    Last Post: 03-15-2017, 06:49 AM
  4. Leading edge dents
    By oldbaldguy in forum Cafe Supercub
    Last Post: 08-22-2007, 10:03 PM
