Results 1 to 12 of 12
Thread: Dakota Cub nose rib at the N brace
    coxcub's Avatar
    Apr 2004
    Devon, England
    272
    Folks
    I'm having a bit of bother getting my head round how the Dakota Cub nose rib at the N brace is 'Modified' to fit at the lower spar cap around the forward strut attach fitting and spacer,
    Any photos or leads to a drawing would be most welcome - thanks
    Frank
    21,306
    It is a different rib. It is notched at the strut attach fitting instead of having the strut fitting going over it like a Piper rib. Not sure if I have a picture, the wings just got covered. Gets screwed to the spar cap face like the other ribs from what I remember.
    coxcub's Avatar
    Apr 2004
    Devon, England
    272
    Thank you Steve,
    The nose rib set as supplied by D C did not include two that were notched so I notched one, as in the photo, to fit in the same position as the original Piper part. This put the bottom of this D C nose rib on the spar exactly where the spar and the strut fitting intersect so there is no cap strip exposed to screw it to.
    Should I reposition it further outboard where the cap strip is exposed?
    I will, of course, have to get another nose rib and and notch it slighly higher - not a problem.
    Thanks for your time
    Frank
    Feb 2010
    Idaho
    285
    I installed Dakota Cub ribs on a J3 and had the same issue, I ordered one from Univair.
    21,306
    Some photos I found.
    4,534
    this is how Univair does it. I’d imagine Dakota is similar
    21,306
    I think you are right Tom, that kinda jogs my memory. Dakota Cub probably had a brain fart and forgot those ribs. Probably worth a phone call to verify.
    21,306
    I was wrong, called Brian at Dakota Cub and he texted me these pictures of a wing they are about to install leading edges on.
    Likes aflyer liked this post
    coxcub's Avatar
    Apr 2004
    Devon, England
    272
    Thanks Steve
    I'm obviously not the only one that has been caught by this one.
    When you spoke with D C did they say if they supplied the nose ribs for that position with the 'cut out' already in them or was it for the customer to do it?
    Thanks once again
    Frank
    21,306
    Quote Originally Posted by coxcub View Post
    Thanks Steve
    Thanks once again
    Frank
    Customer modifies.
    Sep 2005
    SW Colorado
    44
    Steve, I love the way you, one issue after another, pick up the phone and go straight to the source and get an answer that actually means something.
    If I lived nearby, I would be bugging you to maintain my airplane!
    21,306
    Quote Originally Posted by aflyer View Post
    Thanks John. When I first went out on my own in general aviation after spending most all of my career in the Warbird business I figured out that the vendors were for the most part very helpful when I had a question as are a lot of fellow mechanics. Back then my Rolodex was king but my cell phone contacts list has slowly taken over. It is amazing how many vendors I now call friends and the help we provide each other. I like to learn and have learned so much by just picking up the phone.
    Likes AkPA/18, Bill Rusk liked this post
  1. X-Brace
    By Binty in forum Modifications
    Last Post: 10-17-2020, 06:53 AM
  2. V Brace
    By Eddie Foy in forum Cessna: C180/C182/C185
    Last Post: 08-14-2018, 11:05 AM
  3. X-Brace
    By Cub@H20 in forum Member to Member
    Last Post: 03-15-2017, 06:39 PM
  4. Top X-Brace
    By Grizzley in forum Modifications
    Last Post: 03-05-2010, 02:33 PM
