Results 1 to 4 of 4
Thread: Turn coordinator ball not centered
    Jul 2019
    O’Fallon, MO
    34
    On my supper cub, Sitting on level ground, ball is half ball off center. How do you adjust instrument to center the ball? Thanks in advance!
    May 2021
    Arizona, USA
    314
    Quote Originally Posted by womblesd View Post
    Is this a simple stand-alone inclinometer or something more complex like an AHRS driven PFD? In either case the first step would be to confirm that the airframe is actually at zero roll attitude.
    11,477
    The second step would be to slot the screw holes and level the instrument.
    4,141
    Tail down or up in level flight attitude? Tire pressures even?
    To start, level the aircraft left/right and fore/aft. If the ball is not centered, do as Skywagon said and slot the screw holes (this should have been done during panel build). Then once the ball is centered you'll need to see if it stays centered during level flight.
    Likes Stankasica, BC12D-4-85 liked this post
  1. Short Turn Coordinator
    By bofusfly in forum Cafe Supercub
    Last Post: 11-18-2011, 11:06 AM
  2. Tach cable. Long turn or no long turn.
    By Alex Clark in forum Super Cub Sick Bay
    Last Post: 08-04-2011, 11:25 AM
  3. Turn Coordinator or needle/ball
    By Clyde and Susan in forum Modifications
    Last Post: 02-29-2008, 07:59 AM
