Utah-Jay
Heber City, UT
I am planning on a 82” Sensenich GA prop, will I have enough ground clearance with the 26” tires paired with a 10” tailwheel. I really want the longer prop. I will be doing a lot of dirt and gravel strip landings. If it matters it is a Bearhawk Companion, which is the same fuselage as the Bearhawk 4 Place
