J-3 tool kit?
IainR
FRIEND
Underberg, South Africa
C340D44D-575C-4945-9938-EA5DB10E82FD_1_201_a.jpg6B71BC8A-C56E-4BD7-B199-A6A1CEB01679_1_201_a.jpg82490A58-44B7-4F4C-A02B-E89769368BC4_1_201_a.jpg
Finally got my J3 in the air after a lengthy paperwork debacle with our South African Civil Aviation Association. I was wondering what tools do you guys recommend one keeps in the aircraft? I was going with a couple of screw drivers, plug spanner, spare plug, set of long nose pliers.... anything else?
Looks good
Hard to go wrong with:
"screw drivers, plug spanner, spare plug, set of long nose pliers"
I would add/Substitute:
Substitute "screwdrivers" for a single screwdriver with multiple bits (Cheap is good enough)
Vice-Grips
Knipex Pliers
Duct Tape
Letherman(Multi-tool)
A length of safety wire
A handfull of Misc Screws and Nuts for the ones you drop in the deep grass.....
A lot of this depends on what you want to accomplish.... If you're just trying to get home, minimal will do. If you're trying to plan for every enventuality, then nthing you carry will ever be enough...
What tools do you use to do normal tasks on the airplane? I can do 90% of what I normally do with my on-board tool kit. Even when in the hangar with a stocked roll-away I usually grab what I need from my go bag.
Thanks guys, just wanting to make sure there isnt some insiders tip with a specific tool etc. I used to have a share in a twin comanche, one of the vital things was a piece of prestick to prevent nuts falling into the engine bay when re-cowling!
Knipex Pliers
I had no clue what Knipex Pliers were so I looked it up. Knipex is a manufacturer of many tools, including many types of pliers, so that didn't help at all.
Does "Knipex pliers" have some special meaning in this group? I have lots of different pliers but I never heard of Knipex before I came here.
Throughout the adjustment range the jaws stay perfectly parallel. Very handy tool. I have them in my hangar tools but not in my tool kits.
Thanks! Looks like a very useful tool. I've been "wrenching" for over 50 years and never come across these before.
I have the set Flying Miss Daisey have me many years ago. I don't use them on nuts or bolts but the squeeze rivets, straighten sheet metal and lot of other uses. I use the serrated channel Lock brand on those round axle nuts.
I have the set
Looks like you have the set sold by Airframes but there are more sizes available than those and also choices of grip style and steel finish. Perhaps too many choices as I haven't decided which to get (if any).
I admit to using channel locks on my PA-28 wheel spindle sleeve nuts but the FX-3 is only attacked with the proper pin wrench.
Yes, this is the set I have. They to work well on axles nuts with the flast since they are recessed in when on big tires. They all work like a wrench in a pinch as well or when the SAE nor metric wrench quite fits.
https://www.amazon.com/9K-00-80-45-...t=&hvlocphy=9027373&hvtargid=pla-568021556102
One of the reviews from that Amazon link -
"[FONT=&quot]It's Knipex therefore superior quality and durability. As an aircraft engineer I can take apart a whole airplane with these. "
Now I just got to get me some![/FONT]
They are a nicely made tool that just feels right. However, growing up my Dad would get pretty irate if my brothers or I used Crescent wrenches or God forbid a pair of pliers on anything we worked in so mine have a limited usefulness. ;)
In reviewing the suggestions, nobody mentioned a plug wrench. Not much point in carrying a spare plug without a wrench to R and R said plug. I carry said plug socket and a minimal handle…..dunno what they’re called.
I made this from a 3/4" swivel socket wrench and a spark plugs socket. Cut the socket shorter and welded it to the socket end of the wrench. Have one in my daily work box and another in my tool bag in the airplane. Not my idea, Mark Englerth came up with it and I really like it. As you can probably tell I am a tool junkie and have been since I was about 12 years old.
It was called a Plug "Spanner" in the first post.....He must be a silly Britt or South African fella....:lol:
Ahhhh, SO! I assumed the aforementioned “plug scanner” was a term for a gap tester…..:lol:
I like it!
Great for those lock tabs on Piper wings and Lycoming pushrod housings.
South Africans.... cant take them anywhere :p
Whereas we silly Brits get everywhere and some bring our spanners with us. I worked on cars and motorcycles for many years before I came to US. First time in an auto parts store I realized I needed to learn a new language!
best way i heard to create a tool kit is to attempt to do your annual with only your planes tool kit. then treat it like a survivalist and replace specific-use items with multi-use items.
always include a good ghetto-breaker bar like a foot long 7/8's box end for hi tourqe items (doubles as a hammer and cabane V repair repair bar).
learning to properly do tricks with a crescent wrench is priceless for a small tool kit. but a hi quality crescent wrench that will allow a tight fit is critical.
J-3 cub eyebrows are a disaster of vibrations and ive had 3 different eyebrow breakages in 400 hrs of J-3/L4 flying. one of those on my way to fallen nevada that would have left me stranded because i had no way to drill a #40 hole. so while i have not done it yet i mean to pre-drill or "pre-field repair' my outer eyebrow attach points for their inevitable next breakage before im wishing i had lugged around a drill.
if i ever head to alaska i intend to carry an extra previously broken in magento (dont trust new parts) and maybe a couple pulleys so i could lift or move the plane if needed.
oh ya, heres an another tool bag trick to be familiar with in J-3's.... the damn mag switch can either kill you or leave you stranded with a miss-behaving engine. i had both of those happen. the switch's carbon track like a mad man and can short or ground out. so either carry another switch, or replace it with toggle switches and then still carry and extra switch. better yet become familiar with disconnecting the P-leads in order to get home. i knew the p-lead trick and got home 2 times that way. (the alternative option was to sleep in the mountains with no food, no shelter and potential snow coming the next day)
throw dads duct tape in the display case, its more dead then a rotary phone......gorilla tape is 100X's better.
and yes knipex kick ass. ive had the same pair for 15-18 yrs with almost daily use and i am NOT easy on them at all.
+1 for Gorilla tape.
Depending on your fuel setup (if you have wing tanks), a spare gas cap is light and can keep you from being stranded. Zip ties. A bundle of 0.32. I also keep a small amount of cash in my tool bag for when the CC machine at the pump is broken. That's been a saver a time or two.
I still keep a bottle of bourbon in the back for when I find a really tempting looking grass runway on private property. No shotguns in the face yet. Brownwater seems to be a rather universal language.
