Thanks Thanks:  0
Results 1 to 9 of 9
Thread: Original Piper Brake Line Exit
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    294
ID:	57227Click image for larger version.
ID:	57225Click image for larger version.
    Iíve asked about this before and Iím still not quite understanding how Piper had the brake lines exit the fuselage. Iím hoping to keep them inside and exit just behind the front gear fitting. The drawing shows them at quite an angle and Iím not sure thatís correct. I planned on using flexible ss braided lines from the master to the caliper with a union near the top to facilitate float changes. If anyone has ideas pictures that would be awesome.
    PA-12 N418BS
    Nov 2014
    Petaluma, CA
    51
    See this thread for a discussion. I know Steve Pierce posted a covering pic but it’s not in that thread.
    https://www.supercub.org/forum/showt...15-Brake-Lines
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    294
    Yes I saw it and posted in it as well. I just want to be sure before I go cutting and gluing.
    PA-12 N418BS
    Nov 2014
    Petaluma, CA
    51
    I couldn’t find the thread but I had saved the pictures.
ID:	57228Click image for larger version.
ID:	57229Click image for larger version.
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    294
    Awesome!! Thank you very much. That’s what I needed. The gromet under the fabric I can make.
    PA-12 N418BS
    21,200
    That is how Piper did it.
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    294
ID:	57232Click image for larger version.
    Easily done. Thanks.
    PA-12 N418BS
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    389
    would love to see more pic
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    294
    Sure. 1966 model. 2000#, xbrace, dogleg, weld in extended baggage, float fittings, belly pod tabs, rear metal belly, L21 windows etc.
    PA-12 N418BS
  1. 08 OSHKOSH Original Piper Ribs
    By clmaxx in forum Cafe Supercub
    Last Post: 08-16-2008, 05:32 PM
  2. Original Piper Rib Material
    By R. JOHNSON in forum Tips and Tricks
    Last Post: 01-15-2007, 11:55 PM
  3. Original Piper Frames
    By SuperCub MD in forum Tips and Tricks
    Last Post: 07-10-2003, 11:25 PM
