Results 1 to 21 of 21
Thread: Mystery O-320 oil leak - spray hitting front right cowling, oil streak from front latch
    Jan 2013
    Hudson, MA
    100
    After each flight I notice a streak of oil running down the front right cowl latch. When I open the cowl, I don't see an obvious source, but I can see where oil is misting the front right of the inside of the cowling. I also see a little oil at the front of the oil sump and around the starter and generator. Oil is not gushing out and it is not collecting at the lower cowl. Could that be a crankshaft seal?
    The plane just came out of a long annual where the carb, oil cooler, engine mount, air filter and most of the hoses were replaced, but most of the replaced parts are behind or below where the oil is collecting. For what it is worth, compression and engine oil analysis were both excellent.
    Jan 2005
    Fowler, Ks
    665
    Check the generator mounting bolts that also clamp the engine halves together
    I had a seep there and put some thread/gasket sealer in the hole and sealed that seep
    I still had a very minordrip and FINALY tightened the oil cooler lines and no drips no runs no errors!!!!0
    Thanks OzAK thanked for this post
    Clearwater,Fl
    2,596
    I narrowed my leak down to the number one cylinder through stud I think, same symptoms as yours
    seabeggar69's Avatar
    Nov 2008
    Ontario
    1
    Check dipstick gasket.....often overlooked.
    Likes flynlow liked this post
    Upper Peninsula of Michigan
    694
    Lol, I did a top overhaul…that fixed mine
    Richgj3's Avatar
    Apr 2005
    LI,NY
    1,219
    Probably not this and I hope it is not, but I saw a Lycoming angle valve O-360 in the IA shop today that had a hairline crack in the case forward of the left front cylinder. Look closely. It was hard to see and there was only a bit of oil sprayed around.
    Thanks Jon Stewart thanked for this post
    jrussl's Avatar
    Jul 2005
    Madison, WI
    663
    From your description of the location of the oil, it sure sounds like it could be the front seal. Itís easy to check. Just snake your fingers behind the flywheel and feel for oil on the front seal directly. If itís oily, then replace the seal.
    Likes hangarmonkey liked this post
    3,019
    Helps to wash the engine and start over inspecting after a short run. Crank seal, forward lower case halves seam, various crankcase studs, things like that can wear and loosen with time.
    Likes boarfish, Richgj3 liked this post
    supercrow's Avatar
    Dec 2008
    533
    Have seen a couple cracks near the starter mount of 0360's.
    21,168
    I would take it back to the shop that did all the work. They will want to find it and fix it. Oil leaks are funny because they spray all over the inside of the cowl in flight. Look inside the flywheel if you suspect the nose seal.
    Jan 2005
    Fowler, Ks
    665
    Also , if equipped check the quick drain. Thesecan have a occasional drip
    Thanks cubnut thanked for this post
    AkPA/18's Avatar
    Big Lake Ak
    744
    I have a couple of those leaks on my engine. I just rolled up a couple paper towels to find where the leak was coming from. One is from the case have where it meets the oil sump. The other is behind my oil filter adapter. Now I just fly with a little piece of oil absorbent rolled up underneath the leaks and the cowlings stayed dry. But I am a farmer sometimes.
    http://thrustline.com/
    Likes supercrow liked this post
    21,168
    Quote Originally Posted by AkPA/18 View Post
    But I know when you finally quit flying for the season you will be fixing they leaks. Phone has been quiet, lots to report. Figure there are lots of fish.
    Jan 2005
    Fowler, Ks
    665
    Front oil cooler?
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    246
    Push rod tube ?
    Rick Papp's Avatar
    Bristolville, Ohio
    757
    1. Clean engine every nook and cranny. Be thorough.
    2.Allow engine to dry. Blow off any liquids with a shop vac or leaf blower to get completely dry
    3.Puff blue chalk line chalk on any suspected areas of leaks.
    4.Run the engine and usually any leaks will show up by discoloring the chalk.
    Never stay level!!!!!
    3,882
    Yup, or dye penetrant developing powder - comes in an aerosol can, available at welding supply shops. I once had a leak I couldn't find and finally found it that way after about a half hour ground run. Turned out to be a hairline crack in the case.
    Edit: To clean the engine I use paint thinner with a siphoning blow gun - a cheapo Sears sandblast gun in its prior life. Works great.
    May 2017
    1,106
    Quote Originally Posted by Rick Papp View Post
    I use baby powder, but yeah, same idea.
    694
    Is there a smoking rivet?
    Jun 2008
    5
    We had the same issue, turned out to be a defective oil cooler. Replaced it and no leak.
    DR-109's Avatar
    Feb 2010
    Spring Grove, IL
    32
    If you have oil spray on the cowl and donít see any other noticeable leaks, it is most likely the valve cover gaskets. If you have the old cork ones replace them with the silicone rubber ones. Part number RG-75906 from Aircraft Spruce. Follow the instructions in the documents and donít over tighten.
    Thanks Willie thanked for this post
    Likes NoFlaps liked this post
  1. Replies: 8
    Last Post: 05-13-2021, 07:01 AM
  2. PA-18 Cowling latch parts source?
    By supercub in forum Cafe Supercub
    Last Post: 03-27-2020, 11:31 PM
  3. Cowling latch P/N 10816
    By FlatSideShovel in forum Tips and Tricks
    Last Post: 05-07-2017, 04:22 PM
  4. Mystery oil leak
    By coxcub in forum Super Cub Sick Bay
    Last Post: 06-15-2009, 12:29 PM
