Results 1 to 11 of 11
Thread: Sticking Valve or Bad Valve Guide?
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    204
    Engine; Titan 340, TT 218 hrs (yes a new engine).
    #2 cylinder dropped out and had zero compression on a run up (thankfully).
    Upon inspection, borescope shows carbon build up but not any burnt valves. Exhaust valve appears to be the problem. When cycling the prop thru and watching the valve mechanics, #2 exhaust valve does not fully close. Using your hand and putting slight sideways force on the springs, the vavle will snap close.
    I have tried soaking it with MMO, and have done a couple of run ups, but no compression. Always the same issue described above.
    Any ideas or solutions are apppreciated.
    11,364
    Try Kroil on the stem with the valve closed, let it soak for a while.
    https://www.kroil.com/products/kroil...nal-penetrant/
    May 2021
    Arizona, USA
    233
    Quote Originally Posted by aeroaddict View Post
    Any ideas or solutions are appreciated.
    Can you see the valve stem with the boroscope when the valve is fully open? If so, how does this sticking valve compare for build up when compared to an exhaust valve in a good cylinder?
    Perhaps need to pull the exhaust pipe for that cylinder to see the valve stem?
    Either way a bummer on an almost new engine.
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    204
    Thanks for the suggestions. I will remove the exhaust pipe, look at the stem and report back most likely tomorrow.
    8GCBC's Avatar
    Nov 2011
    Oahu
    1,942
    Warranty claim?
    2018 R44
    IA/A&P, ATP, SES, CFII, MEI, Rotor PPL (2500 TT)
    http://www.youtube.com/watch?v=SXI48e1heuo
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    204
    Update; pulled off the exhaust pipe and borescoped the valve stem. It was coated pretty good. I took the advise of a good friend (A&P also) and blocked off the exhaust port to fill the chamber with MMO. Will let it soak for a day or so.
    Since I have the exhaust basically loose, I will borescope the other cylinders tomorrow. Have a fencing project taking precidence over the plane right now.
    Warrenty claim: of course, but I rather try to fix it and fly if possible.
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    204
    Pic: it's a pic of a pic, so not great quality. Looks like a lot of junk built up on the stem.
    May 2021
    Arizona, USA
    233
    I suppose that might give temporary relief from the problem but it won't answer what caused it or prevent it from happening again.
    I just looked at the exhaust valve from an O-360 cylinder I pulled at about 2,800 hours. It looks a lot better than yours.
    Likes Coondog liked this post
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    204
    Well that IS the question. In most conversations about this the main questions are: how do you lean and do you lean on the ground?
    Answer to both questions is yes, but the buildup would imply not leaning enough(?)
    May 2017
    1,090
    If Kroil doesn't do it, try some Hoppies #9. It's great for cleaning fuel injector nozzles as well.
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    204
    Ha! Hoppies make total sense. Thanks
    I should have more time tomorrow to check the other cylinders for comparison.
  1. Oil analysis and sticking exhaust valve?
    By nightflyer in forum Cafe Supercub
    Last Post: 04-09-2021, 06:46 AM
  2. Valve guide wear SB
    By BritishCubBloke in forum Super Cub Sick Bay
    Last Post: 05-06-2006, 12:14 PM
  3. PA-18 Fuel Valve Sticking
    By reileyr in forum Super Cub Sick Bay
    Last Post: 10-02-2004, 08:22 AM
