Results 1 to 7 of 7
Thread: Rust Treatment
    Aeronut's Avatar
    Dec 2019
    Kittery, ME
    54
    Rust Treatment
    I'm working through welding up my empennage and fuselage. It'll likely be 1.5 to 2 years before those pieces are ready for epoxy primer. I've got a light brown tinge developing on the welds that will likely be full on rust at some point. Are there any recommendations for treatments I can put on completed joints until the whole part is ready for primer? If not, would putting a spot spray of epoxy primer on the joints be OK in the meantime?
    Dec 2004
    14
    Many years ago my Dad`s IA would put a light coat of oil on those areas and then clean it off before blasting when the time came to prime.
    Likes Aeronut liked this post
    Aeronut's Avatar
    Dec 2019
    Kittery, ME
    54
    I like that idea rck.
    Wolf Lake, AK
    6,195
    I have a steel fab shop. SOP is the spray a coat of gray primer on welds or grinds as soon as they’re cool. In your case cheapo Krylon primer would protect the parts until you’re ready for paint and is easy to strip-prep.
    Likes OLDCROWE, Aeronut liked this post
    Mar 2016
    1,698
    I use a far better than Krylon primer but any one will help. Even a rattle can of paint since they all will seal the environment out.
    As for oils, they have a chance to penetrate any porosity there might be and be problematic in the distant future.
    Regards, Charlie
    Likes Aeronut, PA-22/20-160 liked this post
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    892
    Since 1947, this is what the pro's use. Made for your mission exactly.Click image for larger version.
    Aeronut's Avatar
    Dec 2019
    Kittery, ME
    54
    Great recommendations! Thank you all!
  1. Chinese Prostate Treatment
    By cubdriver2 in forum Medical Matters
    Last Post: 12-17-2012, 07:29 AM
  2. Corrosion treatment
    By Josh in forum Tips and Tricks
    Last Post: 10-20-2007, 02:02 PM
  3. Rust Treatment
    By T.J. in forum Tips and Tricks
    Last Post: 12-05-2004, 09:08 PM
