wireweinie
FOUNDER
Common issues with com radio antennas include poor range, garbled signals, and directionality. As antennas are simply a calibrated length of wire, unless it is physically damaged, problems are usually due to installation issues. To be installed correctly, the antenna needs the correct polarization, a good ground plane, and a clean attachment to the ground plane.
Polarization simply means that the antenna is pointed in the correct direction to maximize signal output. Com antennas are 'vertically polarized', meaning they need to be pointed up or down. So as long as a standard com antenna is mounted on the belly or on the cabin roof, it should be positioned reasonably well.
All aviation rod type antennas need a ground plane to project a signal with any distance. On a metal skin aircraft, this means that the mounting surface also functions as the ground plane. However, if you mount an antenna on a non conductive (composite) panel or on a fabric covered aircraft, you will need to fabricate the ground plane with metal screen or tape attached to the inside of the non conductive surface. Then the antenna is mounted in the center of the fabricated ground plane. Round ground planes work best and lopsided ground planes give unequal transmitting distances, i.e. if the antenna is mounted close to one edge of the ground plane, it will have shorter range on the 'short side' of the ground plane. Remember, a ground plane is an area. It needs square inches of surface in order to function. Just attaching a ground wire to a mounting screw is NOT a ground plane.
Anything that prevents an antenna from physically and electrically contacting the ground plane needs to be avoided. Gaskets should not be used. Paint on a metal panel needs to be removed from around each mounting screw hole to insure good contact between the antenna and its ground plane. If you are using a fabricated ground plane, ALL mounting hardware needs to contact the antenna and the ground plane.
Example; A customer had issues with a com radio in an ag aircraft (new to him). After I replaced the control com head, the pilot reported that other stations reported him as scratchy/garbled. After I removed the antenna, this is what I found. One pic shows the antenna base and the cork gasket that was attached to it. The other pic shows the metal panel where the antenna was mounted. Notice that the primer was not removed before the antenna was installed.
