This is the best way by far!!! DENNYView attachment 56757
I carry this with me and disconnect the line from at the carburetor and screw this together And hopefully drain this into the belly tank if I've got Room. You can select left or right tank or both to drain if you want.
If you use a plastic container, or ANY collection container, choose one with a standard bung and wrap a rag around the bung-drain hose to keep fumes in the container. They’ll be too rich to ignite.
And what's in the can as filling begins?Must be magic, where do they go when the can fills with gas?
