Results 1 to 15 of 15
Thread: Draining fuel tank on PA18
    cubnut93's Avatar
    Mar 2011
    159
    I need to drain the left side fuel tank so I can replace the gaskets in the fuel gauge. Where is the best place to connect the grading cable to the airplane?
Name:	2014.08.22 assembly (9).JPG
    Likes cubnut liked this post
    4,045
    The fuel tank itself. Clip one end of the cable to a tab or seam on the tank and the other end to the METAL barrel/bucket that the fuel is draining into. This will keep the two pieces at the same voltage so no sparks can jump. Some guys will also attach a second cable from the barrel to a cold water pipe or ground rod for the hanger.
    Wolf Lake, AK
    6,349
    I select the tank and drain through the strainer. Shorter hose, shorter bonding wire. I bond any good grounding point on the airplane to the metal fuel can I'm draining into. If I use a plastic container I make sure the drain hose is long enough to reach the bottom of the container and park my butt on fire watch until it's finished.
    4,045
    Fire watch is aptly named. Once a fuel fire starts, all you can do is watch.
    Thanks Coondog thanked for this post
    Likes Joe McMillen, Hardtailjohn liked this post
    AkPA/18's Avatar
    Big Lake Ak
    743
    I carry this with me and disconnect the line from at the carburetor and screw this together And hopefully drain this into the belly tank if I've got Room. You can select left or right tank or both to drain if you want.
    http://thrustline.com/
    Likes KevinJ, DENNY liked this post
    55-PA18A's Avatar
    Dillingham, Alaska
    680
    Do a search here for draining fuel and static electricity. There's a lot of good info. Above all, do it outside the hanger. I've always drained from the gascolator drain fitting.
    Jim
    Upper Peninsula of Michigan
    685
    I use gascolator to drain as well
    Wolf Lake, AK
    6,349
    If you use a plastic container, or ANY collection container, choose one with a standard bung and wrap a rag around the bung-drain hose to keep fumes in the container. They’ll be too rich to ignite.
    Likes Gordon Misch liked this post
    2,960
    In summer I try to wet the ground around the plane and bucket/container if draining...unless it's on floats. Humidity tends to dissipate static was my thinking but maybe that's just a dream. Winter is drier and static sparks common.
    2,457
    OK so I have had a glass or two tonight, but just put the fuel selector on Right and go fly until the engine coughs then go to Left!! Problem solved! I use jiggle hose for fuel from tanker 185 on long flights but all the STOL guys drain from below cowl I use a simple wire to insure ground of fuel. Do not try to drain or add fuel in hanger!!!
    Denny
    2,457
    Quote Originally Posted by AkPA/18 View Post
    This is the best way by far!!! DENNY
    Thanks A very stick puppy, AkPA/18 thanked for this post
    10,787
    Must be magic, where do they go when the can fills with gas?
    Wolf Lake, AK
    6,349
    Well, Glenn, I’ll explain it for guys who may be interested in information more than cynicism. The greatest area of spark potential is where the drain line is near the container. Since that’s almost exclusively below the top of the filler it makes sense to keep the vapor concentration inside the container richer than ignition level while stabilizing the drain tube to prevent movement in the container neck. What vapors are pushed out through the rag will quickly dissipate in free air and with a rag isolating the tube from the container there’s almost zero spark potential above the rag.
    Have a nice day.
    3,873
    And what's in the can as filling begins?
    4,045
    Well, as entertaining as this is getting, lol, just remember that NO hanger operator allows fueling/defueling operations inside their hanger. This is true of military and most civilian operations. Them fumes is bad.
  1. PA18 fuel tank in a 12
    By barkerlongez in forum Modifications
    Last Post: 06-13-2003, 03:34 AM
