Thanks Thanks:  0
Results 1 to 13 of 13
Thread: Attlee Defroster Install Question
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    283
    Do these deflector brackets really get mounted on top of the hole like the directions say or am I reading them wrong? Could the possibility go in front?
ID:	56658Click image for larger version.
    PA-12 N418BS
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    666
    On most cubs I've seen installed, the deflector goes in front of the hole "grommet" and parallel to the windshield line. I think it just keeps the hottest air from blowing straight on the glass and possibly hazing it slightly.
    Likes WindOnHisNose liked this post
    2,961
    When I had them on a couple planes I ended up bending them to direct the hot air to my line of sight ahead. Might have made them taller to do that. Winter frost on the inside shield made it easy to figure out the best angle. That setup plus a moveable hot air hose kept the vision clear down to -40F or lower.
    55-PA18A's Avatar
    Dillingham, Alaska
    680
    I've seen where too direct, and too hot of air has heat distorted the windshield. The deflectors are probably to help prevent that. May also be to get the windshield cleared off up where your'e actually looking out in front of the plane, not at the engine cowling.
    Jim
    Apr 2009
    AK
    204
    They’re intended to go over the flange/hole like your first pic- they hold the flange in place, as well as keep from melting the windshield.
    nanook's Avatar
    Aug 2002
    northern alaska
    1,732
    They are there to protect your plastic windshield...
    4,497
    Quote Originally Posted by ak49flyer View Post
    That's how i installed mine, They help hold down, the hose will push it up from the inside a little
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    666
    Maybe call Atlee and see what they recommend?
    That would be butt ugly with the deflector over the flange. The flange is pretty tall and you would need to stack some washers under the ends of the deflector piece to make that work. Folks must be holding the flange in place with high temp RTV or something because I haven't yet seen an install with the deflector like it is in pic #1.
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    283
    I called Atlee today and Justin couldn’t remember how he did it in his Cub but will get some pictures this evening. I usually try and follow the directions, but I don’t see why you can’t use silicone to hold them down and put the deflector in front flush with the boot cowl. The #6 instrument screws that hold them down are going to need a stack of washers like mentioned above to keep the deflector from rolling backwards. And I think it might look somewhat awkward.
    PA-12 N418BS
    4,047
    You don't need to glue them down. Hold them down and slide the hose on, all the way up to the lower side of the glare shield, and clamp them down. The hose will hold them in place.
    2,961
    I found I eventually wanted them taller on three so made my own set. Glued with RTV Ultra Black.
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    283
    Unless someone comes up with a good reason, I’m going to put the deflectors in front of the grommets and hold the grommets in place with black RTV on the underside so it won’t show. Between that and the hose clamp they shouldn’t go anywhere. It’ll look more professional.
    PA-12 N418BS
    2,457
    I would set them on top. Putting them in front does nothing! You do not want that air to come straight out of the vent, the tab will help disperse it you will clear more area and less risk of windscreen damage. The scat tubing in my cub is over 200 degrees when I tested it with a heat gun. Mine has a single vent with larger homemade tab DENNY
  1. X-brace STC install question
    By rck in forum Modifications
    Last Post: 10-30-2020, 07:21 PM
  2. CGR 30P install question
    By cubpilot2 in forum All Things Electrical
    Last Post: 04-19-2016, 10:43 AM
  3. Landes Ski install question!
    By beavercub in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 03-05-2010, 01:20 PM
