Does the same engine (for example an O-320) use a different dipstick when it is installed in a Supercub with 35's and extender gear, in a stock Supercub with 8.50"s, or in a C-172? I imagine, because of the inclination of the engine in those different examples they should not indicate the same oil level. Or am I wrong? Or do you just have to learn what your dipstick indicates when you measure the oil with the tail up (with the airplane in a flight level position), and then comparing with the tail on the ground, and check that difference to take into account in the future?
