Im having an oil pressure issue im hoping someone can shed some light on. This is on a Continental C90- 8 mid time with 25 SMOH cylinders using Aeroshell 100 mineral oil. 75 percent of the time with the oil temp stabilized at 180 degrees I am getting about 39 pounds of oil pressure. About 25 percent of the time with the same oil temp I am getting about 32 to 34 pounds of oil pressure. The change in oil pressure never occurs in flight , only after shutdown and restart. The problem is evident at start up as the pressures are lower across the board from start up, cruise and hot idle. The oil pressure gage is a steam gage and didnt have any indication issues with the last engine that was removed 25 hours ago. The PRV spring is new and there is one washer istalled. Any insight would be greatly appreciated.
