Results 1 to 5 of 5
Thread: Where to get weld repairs in Idaho/Utah
    Kodiakmack's Avatar
    Sep 2020
    winters in Utah, Summers in Idaho
    155
    After enjoying my -12 for a little while, we found this….
    lower right longeron at tail cluster. The rest of the airframe seems sound, and was taken to bare metal only 8 years ago and has been hangared in dry climes since.
    anybody have a recommendation on where to take this for repair, and a rough estimate of what ill be out to get her up? I’m comfortable flying her to get fixed. She lives in McCall Idaho and ogden Utah, so that area would be ideal. Currently in McCall. Click image for larger version.
ID:	56278Click image for larger version.
    HAVE FUN. DON'T DIE.
    windy's Avatar
    Dec 2005
    Utah
    776
    I got a new tail section from Univair. If the cracked tube is like that, there may be more corrosion in the tail cluster. It’s where moisture has drained to for over 70 years on your -12.
    This was my -12 tail cluster a few years ago. Notice the knife in the longeron and the tail post that was cracked almost the entire circumference.
    Thanks 8GCBC, 180Marty thanked for this post
    Kodiakmack's Avatar
    Sep 2020
    155
    Wendy, that’s what I’m worried about. Did the gremlins end up doing that repair? Roughly what did it cost you to get back in the air? Trying to figure out just how hosed I am here.
    windy's Avatar
    Dec 2005
    Utah
    776
    No, the trolls didn’t do the repair, thank goodness. It was a competent mechanic.
    Univair has the short & long aft fuselage sections for $3,500-$5,500 respectively. I think the labor for mine was about $5K. I had to go with the long one, because my lower longerons weren’t straight. It only took a day to chop off the old & weld on the new, using plumb bobs & levels. Then 2 more months to recover, paint, & deal with personal issues (not mine). Cutting the back half of the plane off seems drastic, but remember that that half is less expensive than the front half.
    Likes RVBottomly, jrussl, Hardtailjohn liked this post
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,980
    John Roberts, AvWeld. 208-573-0714 In the Emmett area, maybe Caldwell. He built my cub style gear.
  1. weld on axles
    By capav8 in forum Experimental Cubs
    Last Post: 01-16-2011, 12:14 PM
  2. Weld per PPS-40001SP
    By C-YQK in forum Tips and Tricks
    Last Post: 02-20-2004, 11:02 PM
