Results 1 to 10 of 10
Thread: brake caliper question
    Jul 2014
    Norman wells, NT
    98
    Hello,
    This is could very well be a dumb question but....I have Cleveland wheels and brakes on my super cub. Is it "normal" for a caliper to be a little loose to the touch, such as when the brake pads are worn? one side is tight the other is loose, which I just noticed yesterday. The play seems to be on the 2 larger bolts.
    Thanks fir the input.
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    366
    I'm no mechanic. But I think the two 'larger bolts' will be the pins shown on the left. And yes there should be some movement on those pins. I think the calliper that doesn't move may need a closer look at. If my memory serves me, it's the only place graphite is recommended on our aircraft types. (But I'd have to go back to The Mechanics Toolbox to re-read that)
    Some good YouTube stuff on callipers.
Name:	Screen Shot 2021-06-21 at 8.21.07 am.png
    7,563
    Robbie Grove says graphite on the pins. Without pressure you should feel just a bit of looseness. If you lube up those pins with grease or oil, you could start to get chatter. You don't want chatter. I had to go to new pins and torque plate on a chatterer.
    Richgj3's Avatar
    Apr 2005
    LI,NY
    1,211
    Another thing to check, make sure the brake line(s) are not side loading the caliper making it/them difficult to slide. They have to move freely. I spent three rounds of removing brakes and lubing pins until someone smarter than me pointed out that the brake lines looked pretty the way they were routed, but they were side loading the calipers and impeding the ability for them to slide on the pins properly.
    This was on McCauley brakes on a C170B. Same thing would apply to any brakes that need to float on those pins.
    Rich
    21,080
    I would cycle the brakes a few times. Check that your pads have a minimum .100" thickness. Cleveland says to lubricate the pins that the caliper slides on with silicone spray. Won't attract dirt and wear.
    Thanks texmex thanked for this post
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,740
    Yes
    Quote Originally Posted by farm_boy252 View Post
    Hello,
    Is it "normal" for a caliper to be a little loose to the touch.
    behindpropellers's Avatar
    NE Ohio
    6,933
    Logbook entry: Greased brake fittings.
    2,457
    That is a disk brake. So the caliper holding the pads has to "float" movement is good or the inside pad would always have pressure and wear out sooner.
    21,080
    Looks like a leaking o'ring to me.
    Nov 2009
    Edmonton, AB
    116
    Looks to me like someone actually grabbed a grease gun and tried to grease the brakes....idiot
  1. Wanted. Cleveland 30-60A. Brake caliper
    By wingworks in forum Parts and Pieces
    Last Post: 01-03-2021, 08:57 AM
  2. Brake Caliper Orientation
    By NunavutPA-12 in forum Cafe Supercub
    Last Post: 05-06-2013, 10:10 PM
  3. Grove brake caliper rub
    By paul romine in forum Experimental Cubs
    Last Post: 05-16-2012, 11:47 AM
  4. 31s rubbing brake caliper
    By Tim in forum Super Cub Sick Bay
    Last Post: 08-02-2007, 09:19 PM
