Thanks Thanks:  0
Results 1 to 4 of 4
Thread: PA-12 master cylinder leaking
    May 2021
    1
    Looking for recommendations on purchasing, overhauling or changing existing master cylinders. 1946 PA-12 amphib
    thanks
    20,901
    Where is it leaking? Does it have any brake? Is it stock, no booster? If stock and no brake it is probably the diaphragm. https://www.univair.com/search.php?s...linder&Search=
    7,496
    I always carried spare diaphragms. After I discovered cap screws and ball end drivers I timed a diaphragm replacement -ten minutes including unlacing the seat sling. Of course I left out the bottom screw.
    Truck inner tube material lasted for about ten years - unless I let the fluid get low.
    All three Cubs are converted to Grove reservoir systems. Brake maintenance is now reduced to replacing pads annually.
    11,235
    The STC for amphib floats requires high pressure master cylinders.
  1. Master cylinder help
    By P51DACE in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 11-03-2015, 07:52 AM
  2. Dakota Cub Master Cyl - Leaking from Fill Plug
    By Darrel Starr in forum Tips and Tricks
    Last Post: 06-08-2008, 11:42 PM
  3. J-3 Master Cylinder...
    By stearmann4 in forum Member to Member
    Last Post: 12-07-2006, 10:37 AM
