Results 1 to 10 of 10
Thread: Deregistered
    Sep 2009
    Alaska
    60
    Deregistered
    Maybe somebody know. I have the opportunity to purchased a wrecked Tri-Pacer that the previous owner told the FAA it was no longer airworthy. Itís not damaged that bad, Iíve repaired far worse. Though it would be a nice project for me and my grandkids to tackle. It has complete airframe logs, data plate and airworthiness certificate. I looked the N-number up and itís good until 2023. Question is, is there away to get the Airworthy again with the FAA?
    behindpropellers's Avatar
    NE Ohio
    6,928
    Quote Originally Posted by willirw View Post
    Maybe somebody know. I have the opportunity to purchased a wrecked Tri-Pacer that the previous owner told the FAA it was no longer airworthy. It’s not damaged that bad, I’ve repaired far worse. Though it would be a nice project for me and my grandkids to tackle. It has complete airframe logs, data plate and airworthiness certificate. I looked the N-number up and it’s good until 2023. Question is, is there away to get the Airworthy again with the FAA?
    Any airplane out of annual is not airworthy. Depends if they told the FAA that it was destroyed or not. If there is a question, might be worth talking with a DAR before you spend $$ on it.
    Likes Richgj3 liked this post
    May 2017
    1,039
    First thing I would do is actually pull the FAA records. If it is still registered, you should be golden. If the registration was canceled, be prepared for at least a 2 year battle with FAA and take the risk of not being able to register it when the repairs are done.
    Been there, done that with my PA-16. I finally got a letter from the Executive Director of Flight Standards that says when I present photographic evidence of the restored aircraft, they will issue a registration. That took about 2 1/2 years of battling with FAA along with a Congressional inquiry.
    Good luck.
    Thanks flyboyrv3 thanked for this post
    Likes Hardtailjohn, DENNY liked this post
    9,543
    experimental?
    If you are inside it with repairs, go to the dark side.
    Likes DENNY, Utah-Jay liked this post
    May 2017
    1,039
    Sure you can go Experimental, but likely not Amateur Built. You might get Exhibition, but recognize the limitations of that certificate. 91.319 says you can only operate for the purpose for which the certificate was issued. An Exhibition certificate is only for exhibiting the aircraft or proficiency flying, not you Saturday afternoon $100 hamburger.
    akavidflyer's Avatar
    Apr 2010
    Soldotna AK
    192
    You can go get that hamburger while maintaining your proficiency, or any other flying you want to do. After all, any hours spent flying is to maintain proficiency right?
    Feb 2010
    Idaho
    277
    I blindly bought a PA11 project, but I found out from the FAA when I tried to register it that it was reported as destroyed from a previous owner. I was told by the FAA at the time that it could be registered if I could show it was rebuild-able, a picture of the data plate, airworthiness certificate, picture of the completed plane, plus a statement from an IA that it was rebuild-able and now complete. I have to admit I was nervous during the rebuild that all would be well at the end. I sent all my pictures and documentation to a title company in Oklahoma City that checked my information for accuracy and completeness (best $50 I ever spent) and they hand carried it to the FAA. I had my registration two weeks later. I know that is not everyone's experience, maybe dumb luck. I followed Dave's, aka dgapilot, trials on his PA16 project and wondered why our experiences were so different and could feel his frustration. Your project paperwork sounds workable, but you may have to own it to get the process started with the FAA, that of course might be problematic.
    Southern Aero's Avatar
    Jan 2008
    kcco/1ga2
    236
    I have been thru this a couple times.............. If the previous owner sent in the registration as "totaled" or equivalent its fairly easy to get it registered again. I had to do the affidavit by AP, which was myself, to verify aircraft was rebuildable. You say you have the airworthiness cert? You're golden. If they had surrendered the airworthiness cert............ it's dead even if you have the log books. Logs good for engine tho. A "lost" airworthiness is one thing , surrendered (turned in) is another...... it's over for that aircraft. I don't think you have a big problem at all.
    May 2017
    1,039
    Quote Originally Posted by Southern Aero View Post
    Times have changed in the last couple years. Read FAA Order 8100.19. https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgOrders.nsf/0/3d454c9b728ef6b88625832800650ff6/$FILE/8100.19.pdf
    Jan 2008
    kcco/1ga2
    236
    If the project means enuff to you to put a little effort into it then I'd say go for it. The last one I did I had to send in photos of the project and damage/repair. I have others locally that had a fed physically "inspect" the airplane before giving registration........... but they had been in communication with them the whole time. If you can find a local fed that understands tube and rag aircraft, that would help a lot. That document that dga posted does give you and avenue of escape........ depends on the fed you get. I would fill out a registration form and bill of sale, send them in and see what shakes.
    These airplanes came from a time that will never be again. They can be kept alive with raw materials. I think it is worth the effort to keep them on the registry. FWIW
  1. Deregistered Aircraft
    By Patrol Guy in forum Cafe Supercub
    Last Post: 03-28-2014, 08:27 AM
  2. Help with Getting a Tittle for a Deregistered Plane
    By SpainCub in forum Cafe Supercub
    Last Post: 03-12-2010, 01:02 PM
  3. Deregistered Super Cub
    By Steve Pierce in forum Super Cub Sick Bay
    Last Post: 11-25-2009, 05:34 PM
