Results 1 to 14 of 14
Thread: Brake fluid is leaking from parking brake valve PA18
    cubnut93's Avatar
    Mar 2011
    159
    A friend of mine has a PA18 that is leaking brake fluid from the parking brake valve. Does anyone have some drawings of this valve? Mainly interested in the internal parts and how there are put together.
    I have ordered the two O-rings that are inside of the valve. I am hoping that replacing them will take care of the problem.
    Has anyone out there replaced the O-rings in this valve?
    Dec 2016
    Canyon, tx
    827
    You could give me a diagram of a brick and I’d still have trouble reading it.
    Thanks cubnut93 thanked for this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    619
    I rebuilt mine a month or so ago. I have a bunch of pictures and have been meaning to do a write up on how to rebuild them.
    That little o-ring is an inside o-ring in a very small bore and extremely hard to remove and replace. A good dental pick will get it out. Installing the new one involves folding the o-ring in half and inserting it then using the plunger and a poker, one on each side of the o-ring to get it placed over the grove and then gently unfolding it so it falls into the groove. I used the plunger shaft liberally greased with tach lube inserted backwards to finish seating the o-ring in it's groove in the bore.
    Easier said than done though. It's 30 minutes of frustration or the 2 beer equivalent. A good light, magnifying glass, and a set of o-ring picks are crucial. O-rings are MS28775-006, MS28775-010, and the crush washer for the main "plug" is AN900-10
    Thanks cubnut93, Delta Cub thanked for this post
    Likes KevinJ, Colorado-Cub liked this post
    cubnut93's Avatar
    Mar 2011
    159
    Univair gave me MS-28775-010 and MS-28775-113 for the O-rings. The AN numbers were AN6227-11 and AN-6227-5 according to them! I'll have to call them tomorrow and check those numbers again.
    Thanks for the reply.
    cubnut93's Avatar
    Mar 2011
    159
    [QUOTE=Crash, Jr.;804999]I rebuilt mine a month or so ago. I have a bunch of pictures and have been meaning to do a write up on how to rebuild them.
    Can the valve be removed from the master in the airplane or do I need to removed the whole assembly and remove the valve on the bench?
    Thanks Brmoore thanked for this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    619
    The valve should ideally be removed from the plane and rebuilt on the bench. It would be extremely difficult to access it well enough to fish out little seals with it in the plane.
    It's fortunately fairly easy to just pull the diaphragm cover plate with the valve or the booster cylinder if you have boosters. You just need to be double jointed, willing to fold yourself up in the floor in front of the seat, and have a long screwdriver.
    cubnut93's Avatar
    Mar 2011
    159
    Is it easier to remove the whole assembly from the plane and take the valve off the master on the bench?
    I know that there is a crush washer that seals the valve to the nut, but how is the threaded piece that goes between the master & the valve get sealed?
    The one thing that worries me about removing the entire assembly from the plane, is removing the rod that goes from the master pedal to the forward brake pedal. I don't want to bend that rod to be able to remove the entire assembly from the plane. I'll have to check and see if I can just remove the pivot pin/bolt so I don't need to bend that rod. I have had them break before.
Name:	valve seals.jpg
ID:	56144   Click image for larger version.
    fancypants's Avatar
    Jan 2011
    IL
    406
    The connection between parking brake and master cylinder is a 1/8" NPT close nipple.
    You (or your friend) might want to think about upgrading the brakes while you've got everything apart. I like Steve's vented brake boosters: https://www.stevesaircraft.com/vbrake.php
    And if you're worried about breaking the rods, you might also want to look at Dakota Cub's adjustable brake rods. https://dakotacub.com/index.php?rout...product_id=200
    Sometimes it's fun to spend other people's money.
    Yes, definitely. Can't imagine doing it any other way.
    Oh yea, and think about replacing the flathead screws that hold the cover to the frame with allen head screws so you can get on them with a ball head. Plenty of frustrating things about this job.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    619
    Brake boosters make a whole world of difference. I have the North River ones and they work fantastic as long as there are no leaks anywhere in the system. The reservoir is very small so any fluid level change can mess up the whole deal.
    Do be aware though, if you go to boosters there is likely to be some messing with fittings and brake line length due to the boosters being longer than the original diaphragm setup so the fittings have to move forward.
    cubnut93's Avatar
    Mar 2011
    159
    I have removed the master & parking brake assembly from the plane.
    See pix for more info & questions.
    The O-ring that is inside the valve body looks like it will be very hard to remove & replace--wish me luck!
    Univair DID send me one O-ring that was not correct--I have reordered the correct one. Thanks for posting the correct O-ring numbers.
ID:	56164   Click image for larger version.
ID:	56163   Click image for larger version.
Name:	valve labeled.jpg
    cubnut93's Avatar
    Mar 2011
    159
    I used a pick with a 90° at the end. I heated it up with a torch and melted the rock hard O-ring in several places, then I was able to blow it out with compressed air. worked great. Installing the new O-ring wasn't too bad. I used some of the suggestions in this post--thanks for them!
    Now I am waiting for the correct O-ring from Univair.
    BTW--I was some what surprised that I was able to get help with the O-ring numbers through Google. I Googled the AN2667-1 number and it came up with the new number, along with the dimensions at Spencer Aircraft Supply.
    cubnut93's Avatar
    Mar 2011
    159
    Everything is back together with no leaks & proper braking!!!
    Thanks for every ones help!!
    Clearwater,Fl
    2,589
    I recommend chemical extraction for the O ring inside the body. Once the unit is disassembled , submerge in MEK overnight , Use a wooden or plastic tool to extract the swelled softened oring. The interior cylinder walls of the valve must not be damaged.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    619
    If you're gentle and use a brass pick you can extract those o-rings fairly quickly without doing damage. A brass dental pick is a pretty hard to find but invaluable for work on delicate items.
  1. Brake Fluid PA18 -150
    By Bob Stern in forum Tips and Tricks
    Last Post: 01-07-2021, 12:13 PM
  2. Brake Fluid for PA12 Brakes with Scott Brake Cylinders
    By Dan Mersel in forum Super Cub Sick Bay
    Last Post: 11-20-2013, 09:27 PM
  3. parking brake valve
    By pokey in forum Experimental Cubs
    Last Post: 01-11-2007, 04:39 PM
  4. Brake fluid
    By T.J. in forum Tips and Tricks
    Last Post: 08-25-2002, 12:17 PM
