Results 1 to 13 of 13
Thread: Minimum Idle RPM
    Jan 2013
    Hudson, MA
    97
    Minimum Idle RPM
    I notice my idle RPM is a little high-- slightly over 800-- after replacing the carb. My mechanic is doing some final tweaks and was going to adjust that. I believe somewhere around 650 is about the minimum but wanted to confirm that that is what I should see.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    15,490
    Dan, We use 600-650 on wheels. I used to set mine as low as possible 450 - 500 when on floats to minimize idle thrust. 800 will almost keep a light super cub in the air!
    Likes aviatoraf, Hardtailjohn liked this post
    Jan 2013
    Hudson, MA
    97
    Yeah-- that is sort of what is happening to me! I settle down into ground effect and float for about 300 feet.
    On the ground, I am having to ride the brakes while taxiing.
    10,729
    My stroker in my J4 will idle slow enough that the impulse will clatter. Idle below 500 rpm make a huge difference in landing distance. My yellow cub with the composite prop won't idle as low
    n40ff's Avatar
    Oct 2009
    WV
    992
    Engine quits on final, it"s too low.
    10,729
    Quote Originally Posted by n40ff View Post
    If it's too low it won't quit on final, it will quit as you touch down. But we all fly a safe height to touch down, right ;- )
    Likes irishfield liked this post
    RaisedByWolves's Avatar
    Feb 2005
    4,472
    Dead stick funeral fly by?
    n40ff's Avatar
    Oct 2009
    WV
    992
    Well, "as you touch down" is still "short" final I guess......... Not much of a problem with a SC or even a J3 but a real PIA in the J5A to be stuck in the middle of the runway w/o starter.....with a &^%^# Lear Jet benind you. BT/DT
    10,729
    Mine doesn't quit
    55-PA18A's Avatar
    Dillingham, Alaska
    678
    Mine is set about 500. I sometimes get that mag rattle. What is that, and does it cause any problems?
    Jim
    10,729
    Quote Originally Posted by 55-PA18A View Post
    Jim
    Joe, the Slick guru at Kosh says no
    20,922
    Mine has a pretty good lope at idle.
    DJ's Avatar
    Jan 2009
    Bolivia
    320
    I turned mine up to 600-650. It had an unnerving tendency to quit when I closed the throttle on an mild uphill landing if I had the mixture a little lean.
  1. Minimum Washout?
    By ksecub in forum Tips and Tricks
    Last Post: 12-04-2015, 04:58 AM
  2. Minimum water depth
    By SA in forum Cafe Supercub
    Last Post: 08-06-2010, 08:20 AM
