Results 1 to 10 of 10
Thread: Cessna 180 or 185
    Jan 2009
    Twin Cities, MN KANE
    90
    Cessna 180 or 185
    Looking for a Cessna 180 or 185. Willing to take on even a project.
    Nov 2008
    36
    Call Bob Timm At Sea Plane Services at Surfside he might have some leads.
    Dec 2017
    NE
    23
    I have a 67 model 180H with 4500 hrs TT. The wings and tail are new painted white and the fuselage is mostly sanded ready for paint to match the wings. New TCM steel cylinder kits, case was redone by Aircraft Specialties, cam and crank are yellow tagged and ready. I think everything is there for the engine to put together. New 88” Mac seaplane prop with spinner. I cleaned and etch primed the wings and installed new bladders and drains. Factory float kit and corrosion proof. Has original avionics that would have to be rebuilt. I live in western Nebraska 12 hours from Minneapolis. The plane came from Lake Elmo. I have at least $70,000 in this with no labor.
    Akbushrat's Avatar
    Jun 2020
    45
    1954 Cessna 180. Hangered in Willow, Alaska Mid time 0470R. 4 ring pistons 230 hp at 2600 rpm. 1955 nose bowl-No pickle fork. Annual with sale. Imron paint. Crank up front seats. Selkirk interior. Rosien glare shield. Garmin G5. Electronics International gauges. Extended baggage. Sling rear seat. Seats have been recovered and new foam. Float kit. 88” McCauley prop. 55 gallons fuel with new bladders. 10” wheels with 26” air hawks. New: throttle cable, cowl flap cables, mixture cable, overhauled carburetor with new ice detector and EI fuel sender and gauge. New starter. Alternator. Battery on firewall. Air box rebuilt. Mufflers with extenders overhauled. Ongoing updates. Next one is powder coat control horns. Terra radio with spare. Paint 8-9 Interior 8-9. 110 knots 3k feet at 13 gph. Faster at 12k feet at 10 gph. 1700 lbs empty weight. Take the air hawks off and its down to 1600#’s All AD’s done and impecable logs. No surprises, just fire up and go. $165k firm. N3653C
    N1272A for sale also. 66 hr TT since new Piper Super Cub. $180k firmClick image for larger version.
    Akbushrat's Avatar
    Jun 2020
    45
    Correction: 29x11x10 McCreary tires. 10” wheels
    Thanks CWilson thanked for this post
    Likes 62E liked this post
    tharrold's Avatar
    Sep 2010
    Cottage Grove, Or
    18
    Is the 180 still available?
    I am looking for a nice 180. And I always need an excuse to get to Alaska! Send contact info.
    Akbushrat's Avatar
    Jun 2020
    45
    ompb2@icloud.com
    Nov 2008
    36
    Did you find a plane yet?
    If your looking for a float plane I have a 1974 185 on Aerocets with low time factory motor, 3 blade MT, new interior, and any other nice features. It is in Lino Lakes.
    Akbushrat's Avatar
    Jun 2020
    45
    Quote Originally Posted by tharrold View Post
    ompb2@icloud.com
    $165k recent extensive annual of fuel system from bladders to carburetor including carb ice detection and overhauled fuel selector valve. Cylinder work also. Lower cowl reworked and painted inside. Ferrying to lower 48 sept 1.
    ompb2@icloud.com
    Guest
    Both aircraft are in Bentonville,Ar
  1. Will Cessna 210 aileron fit on Cessna 180?
    By 18180 in forum Cafe Supercub
    Last Post: 05-31-2014, 11:46 AM
  2. Cessna down
    By aktango58 in forum In The News
    Last Post: 09-25-2011, 10:42 AM
  3. Cessna 180/185
    By Paul in forum Cafe Supercub
    Last Post: 02-16-2004, 09:28 PM
  4. Used Cessna 180
    By R. JOHNSON in forum Cafe Supercub
    Last Post: 12-23-2003, 11:56 AM
  5. Cessna L-21
    By Todd C in forum Modifications
    Last Post: 03-02-2003, 11:17 AM
