Results 1 to 19 of 19
Thread: Boot cowl access doors?
    May 2020
    58
    Hello everybody, does anybody have access doors installed on one or both sides of the boot cowl in order to have easier access to the instruments in case of the need to do work or repair something there and to not have to disassemble the whole instrument panel to reach back there? Do you think is a good idea or not?
    Meanwhile,...
    5,426
    Pierce made the entire boot cowl removable (in three pieces - top and 2 sides) on my Cub and it has more than one proven its value.
    Likes dwm, Hardtailjohn, Brmoore liked this post
    May 2020
    58
    I saw some pictures of the 3 pieces version. Looks very convenient.
    Wolf Lake, AK
    6,116
    I’ve had my boot cowl sides off better than a half dozen times to work on or add things to the G3X.
    Thanks dwm thanked for this post
    Likes dwm liked this post
    4,430
    it’s pretty damn handy. Couldn’t get to the mag switch from
    Underneath.
    Likes dwm, Hardtailjohn, JDWilliams liked this post
    Nov 2015
    42
    Not a super cub but my j3, the boot cowl (both sides), instrument panel, windshield retaining strips, everything is nut plated and bolted together. Slicker than snot. Complete unobstructed access to the back of the instrument panel and gas tank. Took a bit of time to get everything nicely fit, but extremely happy with zero rivets anywhere. A 100% must in my opinion.
    Sik
    Likes dwm, Hardtailjohn liked this post
    May 2020
    58
    Underneath.
    Looks great! Thank you!
    Wolf Lake, AK
    6,116
    My boot cowl top section stays put so my windshield doesn’t need to come out. Both sides remove in a couple of minutes with a screwdriver. Removing the windshield is the last thing I’d want to do. And FWIW, being able to drop out parts of the panel is dang handy, too. Especially to access the GSU 25. I can reach my connectors from the sides.
ID:	55601   Click image for larger version.
    Likes dwm, Hardtailjohn, Steve Pierce liked this post
    Nov 2020
    34
    Not an 18, but here’s a wrecked Carbon Cub I’m working on. Same principle. The boot cowl was crinkled on the top so I cut it out and replaced it with a carbon fiber panel. Aluminum would work just as well; however,had carbon fiber on hand
ID:	55644   Click image for larger version.
ID:	55645   Click image for larger version.
ID:	55646   Click image for larger version.
ID:	55647   Click image for larger version.
    Wolf Lake, AK
    6,116
    Very nice. I like it!
    Thanks reliableflyer thanked for this post
    Nov 2020
    34
    Thx, Pretty much copied yours
    May 2020
    58
    Quote Originally Posted by Ryan Murphy View Post
    Very nice work Ryan. Thanks for the pictures.
    Wolf Lake, AK
    6,116
    I’d like to see more about Ryan’s and dwm’s projects. I enjoy the building part and seeing what other guys do as these planes continue to evolve.
    May 2020
    58
    Finally because the boot cowl was already finished we decided to do access doors in both sides instead to make a new one.
ID:	55980Click image for larger version.
ID:	55981Click image for larger version.
ID:	55982Click image for larger version.
ID:	55983Click image for larger version.
    Likes stknrddr, Ryan Murphy, skukum12 liked this post
    Dec 2004
    138
    an alternative would have been to cut out the entire side (instead of an access door), essentially giving you a four piece boot cowl with removable sides. From there you'd be one step away from having the bottom portion of the boot cowl removable as well.
    still, your solution is less intrusive, looks good, and serves the purpose.
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    819
    Likes skukum12, Ryan Murphy, dwm liked this post
    May 2020
    58
    Quote Originally Posted by akwing View Post
    We also thought about that option, but we were afraid that it wouldn't be “rigid” enough
    Wolf Lake, AK
    6,116
    I’m not sure what other guys are trying to access with a couple of these pics. If the access panel is below the bottom of the instrument panel you’ll likely see the back side of the interior panel. In my plane the G3X components are mounted on an equipment shelf behind the panel. No access from below. The only way to get to the components and more importantly the connectors is by removing my boot cowl sides, and mine extend quite high up the sides. The better behind-the-panel access solution for most planes is building drop-out panels into the instrument panel.
    In this pic the tray is for my transponder. All other components of the G3X are on the shelf above the txp. The GEA24 connectors have required my attention several times. That box is right inside my RH boot panel. Plan carefully.
    Likes marcusofcotton liked this post
    May 2020
    58
    Hi stewart, you are right, first I will have to remove the interior panels to then be able to access to the back of the instrument panel. My idea of having those doors is the same you had, to have an easy access to the components of the G3X which are mounted on the fuselage pipes behind the instrument panel and not easy to access from the interior of the plane.
  1. J-3 boot cowl and engine cowl on a PA-18
    By j3flyer in forum Experimental Cubs
    Last Post: 12-08-2015, 10:55 AM
  2. Metal for boot cowl and engine cowl
    By Jim Miller in forum Experimental Cubs
    Last Post: 05-13-2015, 10:30 AM
  3. Webbing on nose cowl & boot cowl
    By cubnut93 in forum Tips and Tricks
    Last Post: 05-24-2014, 10:04 PM
  4. Cowl doors
    By Glidertow in forum Tips and Tricks
    Last Post: 08-06-2013, 06:03 AM
