Results 1 to 14 of 14
Thread: Magneto fell off engine
    Altmuehltaler's Avatar
    Feb 2019
    Germany
    36
    Good morning,
    the other day the L-18C of a nearby flying club landed on our airfield. It did so not by choice but was forced to do so. The left magneto (Slick) fell of the engine (C90-8F). Has anyone seen / experienced this?Click image for larger version.
ID:	55580Click image for larger version.
    Unfortunately I did not see the mess personally. I have only these pictures.
    Bjorn
    Mar 2016
    1,658
    I would recommend not using their mechanic.
    Regards, Charlie
    Likes cubdriver2, windy, Stankasica, FdxLou liked this post
    11,161
    It appear the magneto case cracked all around next to the mounting flange. I wonder what precipitated that failure? Perhaps the magneto wasn't seated in the engine properly when the nuts were tightened?
    Likes ron liked this post
    20,845
    Had a pipeline Cessna 150 do a 180 on takeoff when his mag fell off. Nuts backed off. Did this Slick Mag have a Bendix gasket by chance? Structural problem with mag case, poor installation procedure, mag case hitting engine mount?
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,083
    I remember overnighting at Scottsbluff NE years ago and a Dr and his family were heading east in a Seneca. Earlier in the day they had just taken off from Idaho Falls and he saw smoke coming from the left engine. They landed and the mag was off. They had it fixed and continued on. That was an interesting trip. On my return from Flaming Gorge, I landed at Valentine NE for gas and shortly a Bonanza landed. The man with his two kids had come from Cody and he could not figure out why it would not get up to speed------until he went to put the landing gear down-----it was already down. I decided no retractable's for me.
    Likes Jim Hann liked this post
    Feb 2019
    Germany
    36
    To me it looks like only the part of the flange cracked where the bracket sits...
    Feb 2019
    Germany
    36
    I will try to find out if they used Bendix gaskets. You are referring to the issues with Bendix mags (especially dual mags) on Lycoming engines, don't you?
    As far as I heard the plane was not coming fresh from maintenance. It was my first guess that some mistake happened working on it...
    3,886
    As stated above, it looks like there may have been a side load placed on the magneto If it was locked down with the clamps, but was up against the engine mount, the pressure and vibration would cause cracking like that.
    Likes FdxLou liked this post
    Central Maryland
    226
ID:	55654Click image for larger version.
    Had the same thing happen on a DC9.
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,201
    Dc 9?
    "Always looking up"
    Mar 2016
    1,658
    Quote Originally Posted by skukum12 View Post
    Dc 9?
    Yah, they get into real trouble when the magneto falls off.
    Regards, Charlie
    Likes skywagon8a, RVBottomly liked this post
    Central Maryland
    226
    It was a Generator, but it lifted off the case, pulled a few studs, and broke the flange similar to the mag in the OP.
    Feb 2019
    Germany
    36
    The bracket that holds the magneto is a machined one. I cannot remember having seen one like this on a Slick magneto. I know only of brackets which are made of sheet metal. Could it be that the bracket is not the correct one?
    akavidflyer's Avatar
    Apr 2010
    Soldotna AK
    191
    I can't read this thread without thinking of this one.
    https://www.youtube.com/watch?v=8-QNAwUdHUQ
    Likes tedwaltman1, Altmuehltaler liked this post
  1. Magneto's
    By pilotski in forum Cafe Supercub
    Last Post: 03-01-2020, 06:16 PM
  2. Used MMO in leaded rifle bores and lead fell out...
    By Alex Clark in forum Sportsman's Den
    Last Post: 01-20-2010, 05:35 PM
  3. O-290-D2 magneto timing
    By montague in forum Member to Member
    Last Post: 08-08-2007, 06:01 PM
  4. Magneto Lag angle
    By Dan2+2 in forum Experimental Cubs
    Last Post: 09-06-2006, 09:09 AM
