Results 1 to 13 of 13
Thread: Engine break in procedure C85 Stroker
    Dec 2017
    Underberg, South Africa
    61
    Hi all, my J3 is almost ready to get back in the skies. I have overhauled my C85 and done the stroker upgrade and was wondering what every one recommends as a engine break in procedure? I have previously broken in 0320's with a high power setting two hour run at close to sea level, I am a bit concerned that my standard J3 only has just over 2hrs endurance by my calculations and was wondering what everyone else had done?
    7,504
    I just flew mine normally, which is to say, the pattern. I am now at 250 hours with no mishaps save a piece of dirt under the relief valve at ten hours, and I burn a quart every twelve hours. I did use mineral oil for the first 25 hours.
    Thanks IainR thanked for this post
    10,731
    Dec 2017
    61
    Finally got her up and running! I flew around the area for a while at full throttle but the temps crept past the 200 degree mark on my oil temp gauge and I got worried so throttled back and cooled her down a bit. How hot would you be happy to let the oil get and for how long?
    11,248
    See NOTE 1: https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/73e923a0d5faef7e8525670e004526a4/$FILE/E-233.pdf
    Oil temperature maximum limit is 225°F. The temperature is likely to come down a bit after the engine is broken in.
    This is a good article on the subject: https://generalaviationnews.com/2018...rature-engine/
    Jan 2016
    42
    The trick is to run it hard enough to break the rings in, but not too hard that you overheat the engine and glaze the cylinders if they are chrome.
    Dec 2017
    61
    Thanks very much!
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,090
    Look for a Lycoming SB on breaking in engines. They give you a complete program on breaking in.
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,090
    Service instruction 1427C engine break in from Lycoming
    7,504
    Continental says the green arc goes to 225, and you can operate there without damage. Why it gets that hot might be a different story.
    Why would a Lycoming break-in procedure be better than Continental? Smarter engineers? More experience?
    Dec 2017
    61
    Thanks Guys, I appreciate the help
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    619
    My engine must be really broken in since it won't ever get above 140 degrees oil temp. I'm always amazed to see a J3 that actually makes good oil temp.
    7,504
    I am running three, and fly others. On a 70 degree day I expect around 180 degrees on what appear to be good gauges. When it hits 100 I expect 210 on the gauge.
    Likes IainR liked this post
  1. New engine procedure
    By N5126H in forum Cafe Supercub
    Last Post: 01-12-2012, 02:14 AM
  2. new engine break in procedure
    By akpa-12 in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 01-24-2011, 05:37 PM
  3. C85 engine break down
    By fireball111 in forum Cafe Supercub
    Last Post: 04-18-2007, 10:04 PM
