Results 1 to 12 of 12
Thread: Oil leak
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    221
    Oil leak
    I developed an oil leak on my o-200. Started out small and got big in a couple hours. It has 100hrs since an overhaul. I cleaned it up and found itís leaking oil out of the base of cylinder 3 and 2 . So am I lucky and itís the base gasket or unlucky and a through bolt. The oil it coming out about half way up the cylinder on the back towards the firewall side
    10,592
    Try retorquing everything
    cubdrvr's Avatar
    Jan 2002
    1,231
    I've had thru bolts leak and have had luck loosening, pack end with proseal and retorque
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    221
    I will try hopefully that will stop it. My worry is the string gave way
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    221
    Quote Originally Posted by cubdrvr View Post
    That would be great if that would fix it because if I need to split the case I will have to do it in my wifeís dining room. The fbo I used was closed down
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    221
    Glenn what proseal are you using. Is it the one for sealing fuel tanks? Thereís several different ones
    Jan 2016
    36
    Yamabond, what the motorcycle guys use to seal up their engines with. It is easy to remove and separate later unlike proseal. Proseal is good but a real pain to remove.
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    221
    Yep I help rebuild wings on a air tractor gooey s**t. There is some stop leak called proseal that is used in crank cases and different applications. Wasnít sure if that was what Glenn was talking about. Thanks
    Doug
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    221
    Quote Originally Posted by AKjurnees View Post
    Was reading about yamabond . Said it was used to seal case halves on motorcycles I wonder if it would work on Airplane Engines I know permatex is a no-no
    10,592
    Quote Originally Posted by Doug Budd View Post
    Doug
    Wrong cub driver ;- )
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    221
    Sorry
    10,592
    But.....I put my C85 stroker together 12 years ago with this, no thread.
  1. Oil Leak on C85
    By cubman in forum Super Cub Sick Bay
    Last Post: 06-25-2019, 11:14 AM
  2. oil leak
    By 747driver in forum Tips and Tricks
    Last Post: 07-17-2010, 03:48 PM
  3. C-85 oil leak
    By JimC in forum Super Cub Sick Bay
    Last Post: 05-02-2007, 12:45 PM
  4. oil leak help
    By Taledrger in forum Super Cub Sick Bay
    Last Post: 08-24-2005, 08:57 PM
  5. O-290 oil leak
    By RobW56 in forum Super Cub Sick Bay
    Last Post: 02-06-2004, 06:08 PM
