Results 1 to 15 of 15
Thread: O-200 Ignition Issues
    Upper Peninsula of Michigan
    619
    Iíve been taxi testing and running my O-200 in my Exp 11 and have a problem....it starts and runs good on both mags, but when I switch to just Left, or Just Right, it runs rough and pops and backfires. Any suggestions?
    2,352
    What kind of mags? Check internal timing.
    10,606
    Try running it without the leads hooked up. Shut it off with mixture or fuel
    619
    I did run it with P leads unhooked and grounded one then the other mag....runs rough. I’ll check internal timing and harness and plugs next
    Cub Builder's Avatar
    Mar 2011
    North Central AR
    694
    Quote Originally Posted by Dan Gervae View Post
    I’ve been taxi testing and running my O-200 in my Exp 11 and have a problem....it starts and runs good on both mags, but when I switch to just Left, or Just Right, it runs rough and pops and backfires. Any suggestions?
    Check your plug gaps, especially on the lower plugs. Weak spark combined with minimal plug gaps will cause some misfiring. Your plug gaps should be .015 - .019". You can usually run the upper plugs at .015", but will want to open up the lower plugs to .019".
    -Cub Builder
    3,842
    What's the history of the mags? New, used, rebuilt?
    926
    Cold cylinder check on each mag. Sounds like a plug or lead bad on each mag, but on different cylinders for each mag.
    Likes AkPA/18, RVBottomly liked this post
    619
    Used mags. 200 hrs, but they are old Slick 4201s. I’ll check internal timing, but I may get new anyway...I have enough wrapped up in this project...why skimp on mags.
    Likes mam90 liked this post
    619
    I also have to a C85 sitting around with a set of Bendix S4RN-21s complete with Harness that I could put on there.....Them are the good mags. I may do that tomorrow.
    Hardtailjohn's Avatar
    Marion, MT
    853
    Dan, check the lead placement from the cap to the plug. Sounds like the leads aren't headed to the right plug. Also, did you time it with the pin in the right hole?
    Thanks bcone1381 thanked for this post
    Likes skywagon8a, BC12D-4-85, Richgj3 liked this post
    Jul 2019
    Kindred ND
    51
    What is the air temp? O-200 carbs are notoriously lean at mid power settings. Try a full power runup.
    10,606
    Quote Originally Posted by CaseyO View Post
    Never heard that before and never had a problem like that?
    619
    Quote Originally Posted by Hardtailjohn View Post
    Well, I feel dumb....I had top lead wire crossed on left side after I removed them the other day to re-route through my baffeling....oops....I also had a bad plug on the right side.....I replaced 4 plugs because I had 4 new plugs....Thanks for your help.
    Jul 2019
    Kindred ND
    51
    Perhaps notoriously was too strongly worded but it has been an issue over time, most recently experienced with a Cessna 150. It just didn't like partial power (15-1900 RPM) in the winter.
    Marion, MT
    853
    Well....guess how I knew to suggest that? It happens!!
    Likes cubdriver2, Dan Gervae, supercrow liked this post
  1. New electronic ignition
    By Charlie Longley in forum Products, Purchases, Reviews & Prices
    Last Post: 02-21-2019, 12:42 PM
  2. Replies: 3
    Last Post: 02-01-2018, 11:40 AM
  3. Electronic ignition 0-320. Which one?
    By cook11 in forum Experimental Cubs
    Last Post: 05-18-2014, 09:53 PM
  4. Lightspeed Ignition
    By Check Six in forum Cafe Supercub
    Last Post: 06-16-2007, 03:14 PM
