Results 1 to 19 of 19
Thread: new interesting oil change tool
    Wolf Lake, AK
    6,070
    If it purges my coolers Iíll be pleased. I like other items Iíve bought from ASA so I ordered one to try.
    https://antisplataero.com/products/a...l-filter-drain
    10,595
    Just make sure your airline doesn't have any water in it first. More then once I've got water out of an airline in somebody's shop that didn't have a T trap before an air outlet
    Likes Joe McMillen liked this post
    Mar 2020
    Dyersburg, TN
    20
    I don’t care for the beating with a hammer on anything attached to my engine. I think an actual demo on an airplane would have been much better than a bench demo.
    Likes cubnut liked this post
    Wolf Lake, AK
    6,070
    You’ve never driven a punch into a filter can?
    Mar 2020
    Dyersburg, TN
    20
    Not with the force he was trying to sink that tool into the filter. Maybe it would have gone better with the filter secured to an engine.
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    806
    So you get to blow the crap in your filter back through the oil galleys? Is there any concern about that?
    Likes Oliver, cubdriver2 liked this post
    brown bear's Avatar
    Feb 2004
    emporia ks
    585
    I don't like the idea of blowing the oil out of the oil galleys .
    Wolf Lake, AK
    6,070
    All pressurizing will do is push the oil though the filter to empty it. There’s an anti-backflow valve that keeps the oil on the dirty side from draining down. No different than gravity when you punch a hole, just a lot faster.
    Wolf Lake, AK
    6,070
    Quote Originally Posted by brown bear View Post
    When disassembling engines I don’t recall much oil other than what was clinging to surfaces. My primary interest is whether it’ll purge my oil coolers. Probably not a big deal either way but I’m curious and the part is fairly cheap. If it does nothing more than blow the oil through the filter it’ll be money well spent.
    Aug 2012
    In the woods
    806
    Correct me Stewart but doesnít the oil flow through the center of the filter, through the media and then out the perimeter holes? If so wouldnít pressurizing the can on the outside of the filter media backflow the system, potentially releasing whatís trapped in the paper? Or does that valve take care of it.
    All pressurizing will do is push the oil though the filter to empty it. Thereís an anti-backflow valve that keeps the oil on the dirty side from draining down. No different than gravity when you punch a hole, just a lot faster.
    Wolf Lake, AK
    6,070
    Other way around. Into the perimeter and returns through the center. Without the backflow preventer all the filtered particles could return to the engine. When I remove a filter and make the requisite mess, then cut the filter it’s still mostly full of oil on the dirty side. It’d be nice to push that oil through the filter to empty it.
    Thanks Bearhawk Builder thanked for this post
    3,819
    Have you tried it yet? Sure would be nice to reduce the mess.
    Dec 2009
    Michigan
    105
    Is there any concern about air being in the oil cooler?
    3,819
    They're full of air when new - - - So would s'pose it would take a couple seconds for it to fill on engine startup, kinda like a new filter. I wonder if the cooler tends to drain, at least partially, when the engine is shut down for a period of time??
    Feb 2006
    Cortez Colorado
    109
    To heck with using this on my plane which doesnít have a filter, I want this tool for oil changes in my vehicles. I know it is fun having oil running down to my elbow and dripping on my face, but there has to be a better way.
    Mar 2020
    Dyersburg, TN
    20
    I found the quickest way to change oil is to take it to Speedy Lube. This will also keep it from running down your arm!
    Likes hotrod180, Eddy Lewis liked this post
    irishfield's Avatar
    Feb 2003
    3,010
    Quote Originally Posted by Joe McMillen View Post
    Yah, but did they remember to tighten it...
    Likes Eddy Lewis liked this post
    Mar 2020
    Dyersburg, TN
    20
    No...Click image for larger version.
    Likes irishfield liked this post
    Meanwhile,...
    5,409
    Will it matter where you punch it, high or low? Be nice not to have to wack it at the end furthest away from the bracket.
  1. Air tool for cleaning pipe ends prior to welding: Trick Tool 525
    By Speedo in forum Products, Purchases, Reviews & Prices
    Last Post: 02-02-2021, 07:03 AM
  2. Twin Champ? - Interesting.....Very Interesting
    By Grant in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 09-29-2006, 11:46 PM
  3. tool kit
    By harleybubba in forum Tips and Tricks
    Last Post: 08-18-2004, 04:33 PM
