Results 1 to 11 of 11
Thread: Best Supercub gas cap ?
    sohc427mt's Avatar
    Feb 2018
    Belgrede MT
    44
    I am looking for the best gas cap I have 23 gal tanks. I had a motor out yesterday luckily got it on the ground with no problems Felt like a Fuel starving issue I knew I had Fuel tried the Fuel drain nothing , opened cap to look and big vacuumed the vents were not working. On annual rubbers were replaced and blocked ventilation. I want to replace my caps with the best venting caps. ??? I see some Cubs with the extended tubes ? Is that the way to go ? Any advice is appreciated.
    Thanks OzAK thanked for this post
    Meanwhile,...
    5,409
    I use the these on my 150 now 160 hp Super Cub and have never had an issue, well other than the cost when I lost one.
    https://fadodge.com/fuel-cap-vented/
    Likes sohc427mt liked this post
    sohc427mt's Avatar
    Feb 2018
    Belgrede MT
    44
    Thanks my cub is also
    a 160 cub. I will check them out thank you
    11,452
    Yes, those Atlee caps are the way to go. Some 180 hp STCs require the “snorkel” caps, but you don’t need them.
    Jan 2016
    Eagle River, AK
    154
    I think those snorkel caps are also required with the Cub Crafters fuel system STC.
    Likes OLDCROWE, sohc427mt liked this post
    11,452
    Quote Originally Posted by bubb2 View Post
    Yes, for the header less fuel system.
    Penguin's Avatar
    Jul 2012
    KNFL
    119
    I bought the Atlee caps. Does anyone else have issues with the rubber from the gaskets chafing off into the vent holes when you twist the caps on? I sure do. A little fuel lube didn't seem to help.
    sohc427mt's Avatar
    Feb 2018
    Belgrede MT
    44
    I called f Atlee Dodge they recommend I buy the ones with the vent tubes , they said the pressure the tanks and vent well. So I bought a pair.
    7,399
    Spruce has Aeronca caps for under $20, both vented and non-vented. Look a lot more like original Piper caps than the ones from CC and Atlee.
    My j3 wing has a non-vented cap with a copper snorkel soldered in - been working fine for 22 years.
    Meanwhile,...
    5,409
    Quote Originally Posted by Penguin View Post
    Haven't had that issue and been running them for 10 years but the fuel lube sure helps because they are a tight fit.
    Likes sohc427mt, Scooter7779h liked this post
    Wolf Lake, AK
    6,070
    Carefully bend the ears to open them up a teensy bit. Mine were too Effing tight, too.
    Likes WindOnHisNose, sohc427mt liked this post
  1. 185 vs Supercub
    By isilverone in forum Cafe Supercub
    Last Post: 05-26-2017, 02:43 PM
  2. Thank You Supercub.org
    By RedEye in forum Cafe Supercub
    Last Post: 05-07-2010, 06:40 PM
  3. supercub in ad
    By redrooster in forum Cafe Supercub
    Last Post: 12-07-2005, 09:23 PM
