Results 1 to 10 of 10
Thread: O-320 STC change during rebuild..
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    216
    In the process of getting my PA-12 back together after the ground loop. The wings are up for rebuild and recover in Pittsburg... Probably not going to recover fuselage as there was no damage and it was recovered with the poly fiber process back in 2008 and hangered ever since. The 12 currently has the Kenmore O-320 STC on it but was thinking about maybe changing to the the Univair / Stoddards STC. I've done most of my research here on it...
    I spoke to Crosswinds about their STC and he said I should just stick with the Kenmore.
    Any thoughts on what would be involved from going from the Kenmore to the Univair/Stoddards? Is it just new engine mount and fabricating cowlings? It would be nice to get that CG a bit further back. Any pics of the Univair / Stoddards would be greatly appreciated.
    Likes AZinAK liked this post
    Apr 2017
    2
    I have the same STC currently and have wondered the same. I just had mine weighed. EW of 1175 with a EW Arm at 12.89. What is your CG currently at?
    11,108
    Before you go spend a bunch of money for STCs and alterations, why don't you just hang 10 pounds of ballast at the tail? 10 lbs at 200" will move the CG back 1.58". Fly that to see how you like it. Ballast is an acceptable and approved method of moving the CG.
    Make a temporary installation to find out if you like it, then do a more permanent installation.
    Make a simple weight and balance program on your computer. Try different weights, watch the CG move around.
    Thanks daedgerton thanked for this post
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    216
    But spending money is fun...
    RVBottomly's Avatar
    Sep 2017
    1,056
    So now you give me an idea to put in a small baggage compartment near the tail. My shoulder bag typically weighs 15-20 pounds. I often bring it on trips. Might as well put it to good use if it would help.
    Or extra water bottles, cans of beans, etc.
    May 2017
    923
    Be careful when you put loads at the extreme. While you may be within the CG envelope, moving mass at the far end of the fuselage can have a significant impact on the spin dynamics of the airplane. The inertia of that mass reduces the effectiveness of the rudder in stopping the rotation.
    Likes AZinAK, JDWilliams liked this post
    11,108
    If the load is of great significance then I would agree there is a possibility. 10 lbs in a -12 or -18 in this location is not very much. My -18 has this much ballast at the tail with only positive results. I have placed 120 pounds of ballast at the extreme aft end of a Pilatus PC-6 to bring the CG within range with no adverse effects. This was done with a field approval and with concurrence of Pilatus engineering. If a plane had marginal spin recovery characteristics in the first place, then this could be a consideration. A -12 has no issues in this respect.
    2,346
    I usually carry 20-30 lbs of tools survival gear most any time I fly. Adding a aft compartment to hold tools and tiedown gear is a no brainer if you want to help with CG.
    3,833
    Use a fat tail wheel.
    May 2017
    923
    The Howard Is a much larger and heavier airplane. With ballast on the tail post, it gets a placard that restricts intentional spins. Mine had about 20 lbs on the tail post to bring it in the forward limit with just the pilot, full oil and full front fuel tank.
  1. Change Oil?
    By Eddie Foy in forum Cafe Supercub
    Last Post: 06-13-2015, 10:20 AM
  2. Need to change my name
    By CuBob in forum Cafe Supercub
    Last Post: 05-07-2010, 10:50 AM
  3. ID change
    By Aviator in forum Cafe Supercub
    Last Post: 01-16-2004, 08:54 AM
