Colorguns
PATRON
Bloomfield NY
I have labored starting with a XLW starter as well as a friend in his -18 same starter. I have the Gill battery and he has the SBS-16 battery. First blade can be up on compression and have to re-hit the button to turn it over past that and then it seems to go well.
I have been told the XLW starter don't like being strained and this creates issues with them.
I will be looking at the old Prestolite starter as I could use some weight back up front to help with CG and my loading. It is nice to have it set that you really don't need to think about the CG and loading and when flying there is almost no trimming needed when I had it set up before the change of the prop. LOVE this PROP!
Doug
Doug
