Page 6 of 7 FirstFirst ... 4567 LastLast
Results 201 to 240 of 241
Thread: Sensenich Ground Adjustable Prop
  1. #201
    22,202
    Those are some little tiny tires!
    sj
    They make it challenging with a cross wind, shimmying Baby Bushwheel tailwheel 250 lb passenger at gross weight. No shimmy today with the 3200 and the landings were a piece of cake but you better not drop it in cause it'll jar your teeth. Add in the comments from the back seat FAA test pilot when the landing isn't so smooth.
  2. #202
    22,202
    Starter button!? The cub gods are trying to send you a message. You donít need the button or the starter attached. What you need is a good shoulder surgeon
    Keeping my starter and foregoing the shoulder surgery at this point. I'll leave that hand propping to you young bucks.
  3. #203
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    867
    I think you can probably throw a comment or two back
    Thanks KevinJ thanked for this post
    Likes KevinJ liked this post
  4. #204
    22,202
    LOL, he has been good, I have gotten some interesting sounds when I pull the stick all the way back in the flare.
  5. #205
    Utah-Jay's Avatar
    Aug 2020
    Heber City, UT
    435
    Iíve had a few people try and order some for exp, sensnich must be really busy already. They never got back to them.
    I have had my 82Ē GA prop for several months, but then I figured once the certification happened (long over due obviously) they would be hard to get. Hence I ordered mine a LONG time ago.
    I like having things in hand even well before I need them.
    Bearhawk Companion QB Builder
    Revo Sunglasses Ambassador
    https://www.instagram.com/jay_townsend_utah/
    https://www.youtube.com/channel/UCQ0...tBJLdV8HB_jSIA
    Likes Busdriver liked this post
  6. #206
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    1,083
    Steve why is your gear splayed soooo far OUT??? Can't imagine how far that must tilt those tires when your at GW??? Is that being caused by the shocks not having correct tensions; to hold the weight of the plane?? Not being critical here, just an honest question?
    The new Cub looks great.
    E
    Thanks #JoeM8848 thanked for this post
  7. #207
    supercrow's Avatar
    Dec 2008
    638
    Earle, it will be interesting to get Steve's take on this but I think you will find it works best for the type of off airport landings he is making down his way. The developers of the shock systems we are seeing the last few years refer to the travel limits of there systems as compression and sag. Most recommend exactly what you are referring to as preferable because it increases the overall distance the unit is allowed to travel which simply means more usable shock absorbtion in particularly rough ground. And I suspect the slight splay out might also increase stability at touch ground on very rough areas? Interested to hear the take others have on this. The monster shock system I use talks about setting them up to allow that extra movement. I prefer a more level stance for mine, but i am not generally using like Steve does down along the river.
  8. #208
    22,202
    E
    Spinning it around and it wasn't bottomed out.
  9. #209
    Meanwhile,...
    5,557
    sj
    Somewhere in Graham Texas there's a BBQ Grill up on blocks...
    Likes Steve Pierce, AkPA/18 liked this post
  10. #210
    22,202
    E
    This is just pushing it straight back, Burl's AOSS.
  11. #211
    Aug 2003
    1,416
    Yes, but what's with the tiny tires on "Double-Oh-Six" in the back corner ? The Sensenich prop should work great on a Scout.
    Thanks. cubscout
  12. #212
    Jun 2009
    Northern Maine
    1,083
    Gotcha
  13. #213
    22,202
    Concluded the landing test yesterday with 6 landing starting at dawn. Will schedule the noise testing in a few weeks and we are hoping to use my airplane since I have approval for the prop and would save switching the airworthiness certificate from standard to experimental which involves a DAR coming from Waco twice to do. I will have to take off and climb over the microphone at a certain altitude. This is the last step and hopefully the data will get processed and submitted and an STC granted soon.
    This is the test airplane with the ground adjustable prop.
    Flight test briefing with the FAA and Sensenich. Alley was the supervisor.
    The crew. I learned a lot about props from Jon Bristol and Steve Boser at Sensenich and a lot about test flying procedures from Tom Bryant. Bob Brock kept all the i's dotted and t's crossed.
    Thanks h2oavi8r, cubscout, OLDCROWE, JohnnyR thanked for this post
  14. #214
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    927
    Debating on which prop to put on my project. So once this prop becomes certified how long before they’re available?
  15. #215
    Dec 2017
    NE
    92
    A friend of mine has a PA 12 with an O320 on the front and is looking for a prop. When this prop is certified for O 320 will it only be for the PA18 or will the certification include other piper taildraggers with similar type certification PA11-PA12-PA18?
  16. #216
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    1,027
    Just curious, but why wouldn't the noise test be conducted in the same configuration (same aircraft) as the other performance testing?
  17. #217
    22,202
    Quote Originally Posted by Supercubrancher View Post
    The STC will be for the PA18 with an O-320 engine installed both 150 and 160 hp. The prop is type certified on the O-320 and O-360 engines and that data along with the STC data for the PA18 can be used to get a field approval or DER approval of the prop on other aircraft. It has gotten approval via that route on a 180 hp C172 converted to tail wheel and on a Pacer. I was considering pursuing an STC for the Pacer but having seen what this project took I don't think I have the time, patience or money to do it.
    Thanks Supercubrancher, soyAnarchisto, Broncoformudv thanked for this post
  18. #218
    22,202
    The performance data has to be interpolated to come up with the altitude at which the altitude the airplane has to climb over the microphone on take-off. The aircraft would again have to be put into the Experimental category and then back to standard which takes a DAR two trips, expense etc. If I use my airplane which has approval to run the prop it can be one trip to prove compliance.
    Likes Broncoformudv liked this post
  19. #219
    May 2021
    Arizona, USA
    1,027
    Ok, thanks. I was assuming the test aircraft would be dedicated to the program and stay experimental until the program was completed.
  20. #220
    1,442
    Problem if you leave the airplane in Experimental R&D/Show Compliance is based on 91.319, it can ONLY be used for the purpose for which it is Certificated. If it stays Experimental, it can only be used for the testing and nothing else.
  21. #221
    22,202
    That is why it was returned to standard and to it's owner. We never know how long these things are going to take.
  22. #222
    May 2021
    Arizona, USA
    1,027
    (deleted post about unrelated cert programs)
  23. #223
    Jun 2014
    14
    Hey Steve:
    Do you have any experience with the 3 blade 78Ē STOL prop? I debating whether to get that or the 82Ē two blade. Itís for a Carbon Cub EX1 Iím building that will have the CC363i engine.
    Gregg
  24. #224
    22,202
    Quote Originally Posted by Yeti_MN View Post
    Hey Steve:
    Do you have any experience with the 3 blade 78” STOL prop? I debating whether to get that or the 82” two blade. It’s for a Carbon Cub EX1 I’m building that will have the CC363i engine.
    Gregg
    I do not. I will ask about it though.
    Thanks Yeti_MN thanked for this post
  25. #225
    May 2012
    SE Montana
    492
    I see on the Sensenich website that they have a ground adjustable prop for lower hp engines. Anyone here heard anything about those, good, bad, or otherwise? I'd like to try one on my C90.
  26. #226
    22,202
    There is a good prop coming for the C90. Molds are made but be a year or so. C76AF is available now.
    2F0K6 C76AF: 76" diameter in a 2 blade hub, wide blade to meet inertia requirements for C-90/O-200
    2F0K6 C78CFF: 78" diameter in a 2 blade hub, new design (mold should be getting cut within the next couple of weeks), composite layup redesigned to meet C-90/O-200 inertia requirements, anticipated ~100-150 RPM higher static engine speeds for similar cruise settings
    C78CFF-2 is the tip trimmed to 76" diameter.
    Likes alaskadrifter liked this post
  27. #227
    4,002
    I've been watching this Sen 2FO prop for my C-85 Stroker, a C-90 equivalent. It will revolutionize the performance especially on floats.
    Steve, what are the inertia requirements mentioned above?
    Likes mixer liked this post
  28. #228
    Rochester, NY
    206
    Got one on a 0-235. Great performer on floats, wheels, wheel skis. The water takes a little finish off but otherwise no problems at all.
    Jim
  29. #229
    22,202
    Not sure, I will find out.
  30. #230
    Upper Peninsula of Michigan
    832
    So this will be the same prop for C90, O200, O235?
  31. #231
    4,002
    I see page 6 here re Installation Instructions notes Mass Moment of Inertia = 3900-4000 kg/cm^2 Not sure what that means except it'll not blow apart yet?
    https://www.sensenich.com/wp-content...2021-11-12.pdf
  32. #232
    Nov 2020
    AKID
    5
    Question Different pitch pin markings?
    Pitch pin question:
    I have the 2GOM8 C82BGF installed on a PA-18-150 O-360. Pitch pins marked 2-7. Chart from included instructions below.
    I also have the 2GOM6 C82F installed on a PA-18-150 O-320. Pitch pins marked 0-5. No chart included for PIN number to pitch. Do pins 0-5 = 2-7 and are the corresponding pitches the same??
    Thanks Just call me Al thanked for this post
  33. #233
    4,002
    You might measure the diameter of each pin where it contacts the blade stops. See if they are the same for similar Gage# ? Also, https://www.sensenich.com/wp-content...1297966148.pdf
  34. #234
    22,202
    Quote Originally Posted by See_ya View Post
    Pitch pin question:
    Pins are 0-7 incrementally increasing pitch. Same blades, different hub. There will be a chart when the prop for the PA18-150/160 is STC'd I am almost certain.
  35. #235
    Nov 2020
    AKID
    5
    pins are stamped 0-5. But I get it.
    thanks much. I assumed they were the same otherwise.
    best, Brett Click image for larger version.
  36. #236
    22,202
    O-320 prop comes with 0-5 pins and O-360 prop comes with 2-7 pins.
    Thanks soyAnarchisto thanked for this post
  37. #237
    22,202
    Looks like we will be able to use my airplane for the noise testing and hoping to do that before Thanksgiving. From what I know that is the last step in obtaining the STC.
  38. #238
    Nov 2021
    25
    I just broke down and got an other borer prop for the ski flying season -- just cant wait any longer.
  39. #239
    May 2002
    Bellingen, NSW, Australia
    759
    Any sign of the noise testing?
  40. #240
    22,202
    Quote Originally Posted by BritishCubBloke View Post
    No, more ideocracy. I update this thread as progress is made.
    Thanks BritishCubBloke thanked for this post
  1. The Sensenich ground adjustable prop info
    By scottsville in forum Cafe Supercub
    Last Post: 02-22-2020, 04:30 PM
  2. Sensenich ground adjustable STOL prop
    By Bender in forum Piper: PA-18 Super Cub (and L18C & L21)
    Last Post: 01-28-2020, 10:01 PM
  3. Sensenich ground adjustable prop
    By TcraftF21 in forum Products, Purchases, Reviews & Prices
    Last Post: 01-17-2017, 10:41 PM
  4. Sensenich 2EK Ground Adjustable Prop
    By R. JOHNSON in forum Experimental Cubs
    Last Post: 12-04-2008, 01:13 PM
