Results 1 to 6 of 6
Thread: PA-12 Electrical
    Jul 2019
    4
    PA-12 Electrical
    redoing the entire electrical on the 12. I'm a mechanical guy so this may be tough. I found one wiring diagram 10207 which is barely legible. Any thoughts/advice on where to start. Help!
    4,070
    Yes! Throw away the diagram for the original system.
    Just use a master relay and bus like almost all aircraft (other than Cub types).
    Jul 2019
    4
    Thanks Web, what components should I retain in the system so I don't have any issues with the IA?
    Would you place the bus bar behind the panel with all your switches and CBs right there?
    4,070
    If you have problems with your IA over rewiring a PA 12, shop around for a new IA.
    Place a master relay on the battery tray. If you have a starter you'll need a start relay. Bus bar on breakers/switch breakers on the instrument panel. Push-pull breakers for stuff that just stays on. Switch breakers for systems that get turned on/off regularly, such as lights. Wire all systems to the bus bar for power.
    There are dozens of details, when you start planning and installing, so ask your questions. And check your PM's for my phone number, if you want that.
    ak-flyer's Avatar
    Apr 2009
    ANC, AK
    20
    ak-flyer's Avatar
    Apr 2009
    ANC, AK
    20
    Quote Originally Posted by ak-flyer View Post
    Here is the basic configuration to give you some ideas. Before I get ripped apart, this is a visual aid only.
  1. More Electrical Questions
    By Binty in forum Modifications
    Last Post: 11-29-2012, 08:26 PM
  2. Electrical Q:
    By Aviator in forum Tips and Tricks
    Last Post: 10-02-2012, 12:08 PM
  3. Electrical/No Electrical that is the question
    By High Country in forum Cafe Supercub
    Last Post: 07-05-2008, 02:10 PM
  4. Another electrical question....
    By CptKelly in forum Experimental Cubs
    Last Post: 05-16-2008, 09:40 AM
