redoing the entire electrical on the 12. I'm a mechanical guy so this may be tough. I found one wiring diagram 10207 which is barely legible. Any thoughts/advice on where to start. Help!
If you have problems with your IA over rewiring a PA 12, shop around for a new IA.
Place a master relay on the battery tray. If you have a starter you'll need a start relay. Bus bar on breakers/switch breakers on the instrument panel. Push-pull breakers for stuff that just stays on. Switch breakers for systems that get turned on/off regularly, such as lights. Wire all systems to the bus bar for power.
There are dozens of details, when you start planning and installing, so ask your questions. And check your PM's for my phone number, if you want that.
